Phoenix Android Audio retains Sync 3
G
Guy
Enable developer options by going into settings, more, under system I think. Then tap on “build”. Something like 10 times. The dev options will then appear under the general settings area.
From there.. go down and enable “disable hardware overlay”
Google “how to enable developer options for android” you’ll find an easy how-to
This post is relevant. I didn't realize there were to plugs on the back of the radio brain... also, at first I got no sync - the cable that plugs to the sync brain was not seated properly.
I found how to change the refresh rate to high but I still cant find the GPU setting?
G
Guy
Kona,
You hit the nail on the head. This radio is for a tech nerd. This is not a simple “ plug and play and it just works” like a well refined android phone or apple product.
The install looks easy, but the connectors are finicky and DELICATE. The software is a little quirky out of the box. There are certain little buggy type things that you have to work around.
A few examples.... the screen refresh and hardware overlay smooth out the visuals are performance. There is no manual for it. I found it online on a forum.
The blue tooth on the unit is just average quality for cell phone use. So I use sync for that and don’t bother to connect my phone via blue tooth to the unit. I’ve found the implementation of Bluetooth sync is actually very good and phone calls seamlessly pop right up no matter what you’re doing.
I stream direct from the unit and that works great. Waze navigation works perfectly and is full screen. You can listen to your sync 3 radio or stream your favorite service right on top of it split screen. The downside is that if you are using sync, you won’t get the Waze audio/voice prompts. Low level annoyance.
All the controls for HVAC and such work as you’d expect. YouTube works. Other apps like Ring doorbell, garage door openers, Etc.... all work. Email works. Web works.
I haven’t used android in years, but I was at one point very fluent with the os. I was able to knock most of the rust off at this point...
My advice to anyone considering the unit.... don’t buy it if you’re not a tech person — you’ll get frustrated. Don’t buy it if you are OCD about everything working exactly the way you’d intuitively expect it to work. See above quirks. Don’t buy it if having unused quick launch icons bothers you. There are features and cable connections you probably won’t use for things like additional cameras and audio video outputs.
If you have an average to above average skill set with tech, enjoy working through android quirks, like new gadgets, and hate the current look of your interior... this thing is AWESOME.
Will a novice get into your truck and find things that don’t make sense on the new tablet? Yes. Will they not know how to open sync? Maybe. Will they get flustered because to use sync and Waze together.... first you have to open sync... then you have to open Waze. Then to change stations you have to use the steering wheel controls. Going back to sync screen will cancel your Waze navigation. Would that drive some people nuts? Maybe? But I know the unit and the truck inside and out. It’s not a big deal to me.
Does that make sense? It’s completely worth the money spent and I love the product but you have to know how to use it. I could sit you in my truck, do a demo of it... not miss a beat.... and make it look absolutely perfect, simple, flawless in operation.... without you ever knowing there are software quirks... because there are work arounds to all of them.
If I then tell you to play with the radio, without ever using it before.... you’re going to stumble into quirks and get frustrated, say it’s garbage, and tell me to throw it away.
Dang Phoenix should be paying you for product support haha. Your help I think is the only reason people are getting anywhere with the unit and it is somewhat working properly. Problem is I think you might be the only one that has positive feedback that this unit is worth the money and any initial headaches its causing.
If you get any free time an install video and run down would be so awesome!
nikhsub1
Los Angeles
So you are not using carplay then? How exactly are you connecting your phone? Bluetooth to the unit? You mention bluetooth sync, this confuses me...
nikhsub1
Los Angeles
Nevermind that I figured it out... I have a weird issue though, waze through carplay - the nav is waaaaayyy off. It won't recalculate etc. Seems like the nav antenna is not plugged it guess Ill have to recheck that even though I know I did...
K1llD4shN1n3
Colorado
Waze through CarPlay should be using your phone’s GPS
amp
TX
For those that are wondering where the:
Force GPU rendering
Disable HW overlays
switches are, here is how you get to them.
SETTINGS -> More settings... -> Developer options (in order to see this option, you have to enable it. Just google "android enable developer options"
GCATX
King Dingaling
Central Texas
Okay, I plugged in Both GPS antennae, now SYNC GPS works.
Still no sound from the tablet. I pulled apart and snapped back in the "T" connectors behind the CD player. I am still not getting any sound out of Phoenix apps, whatever is on the factory stereo is still coming through the truck speakers while Youtube is playing on the Phoenix.
Anything else I should check while it's out?
Thanks.
G
Guy
Console does need to be closed for sound from the tablet to come thru.
Do this. Close the console. Open the blue tooth menu. Connect your phone via blue tooth and stream. See if you get sound.
Then try to stream something on the tablet. Still no sound?
