Phoenix Android Audio retains Sync 3
nikhsub1
Los Angeles
OK well I feel better I'm not the only one with the GPS. Everything else works as it should on my unit and I agree with Guy, 99.99% of the issues are with a plug not all the way seated.
nah_tan
So I performed the .img update (no issues with that) and the simple can update per video instructions and did save and reboot and it went black after the splash screen. Sync seems to be working fine as I can control my radio and volume and voice dial. But WTF!?!
G
Guy
After you update it.... you have to use a paper clip and press the master reset button. I have done a couple updates and have had that issue. That is more just an android software thing.
Once you reset it.... it’ll come back on.
Let me know what happens when you swap the antenna.
Then if that doesn’t work let me know what happens if you unplug just the tablet antenna and leave the sync antenna in.
If none of that works, we then know it is related to some sort of interference that is being introduced by the installation of the tablet itself.
Next step would be to pull the plastic speaker out and OFF of the CD player. It’s a magnetic field on top of part of the brain.
—- report back on the above things and let me know.
G
Guy
So I used CPU z and did confirm the specs. It’s 7.1.1 android with 2 gigs of ram and it is the rock chip that’s advertised.
But further... mine came with ROOT ACCESS.
Now that offers up some interesting possibilities.
TXBrian
Dallas
nikhsub1
Los Angeles
I was able to do the img update but i couldn’t find the info on the canbus update. Link?
Herkguy
Little Rock
Guy how much data have you been using on that Harlan with day to day usage? I bailed on the T-mobile version of that since it was only 2 gigs and I could easily see myself going over that. Tethering to the phone has been a bit annoying though, probably works 75% of the time, the other 25% I have to fiddle around with it to get a connection.
