Phoenix Android Audio retains Sync 3
GCATX
King Dingaling
Central Texas
I’m still thinking the factory navigation is off because the original sync 3 brain is mounted 180 degrees out from the original orientation. There is no way to test it because the cable they provide is too short.
That's an interesting thought. Could it be that simple?
Jonnie510
NorCal
I think it could be. The navigation feels like it thinks it’s upside down. I can mount the unit right side up with 2 screws but the cable isn’t long enough.
G
Guy
Phoenix tells me they fixed the OEM sync nav. It has to be flipped over and they provide a longer cable. Jonnie was right.
They also say they have the 360 camera button now working as you’d think it would.
Just about every bug is getting cleaned up in time for px6, so I’m told.
GCATX
King Dingaling
Central Texas
That's great. Any mention of sending out longer cables to old customers? Seems like the right thing to do.
amp
TX
******* OEM NAV FIXED *******
I am local to the shop and they reached out to me to see if they could use my 2018 Raptor 802a (sync3), to test the PX6 and troubleshoot a few issues. I previously had the older version and got fed up and returned it. An afternoon with their engineers, we figured out what was wrong with the OEM navigation and why it wouldn't navigate correctly.
The Sync3 module is UPSIDE DOWN. Another piece of good news, is that all of us can fix it ourselves. When you rotate the Sync3 module 180 degrees, you will only use 2 screws to secure it, rather than 3. The 3rd hole is just left hanging. I'm attaching a picture for reference. The screws are indicated by the red circles. Button it all up, and now factory nav works as it should.
Some other things that I noticed were fixed, was the back up camera. It's the same as the OEM camera when you shift it in reverse. The image is a little dark and possibly stretched, but not by much.
The tablet is noticeably snappier, and apps like google maps work fine. The search bar is where it should be, etc. i think this was due to the tablet now running Android 8.1, and the beefed up hardware.
Haven't had a chance to mess around with other apps, but will do so possibly tomorrow.
One quirk I noticed while driving home, was that when you are listening to Satellite music through the console, the steering wheel FWD and BACK arrows (for music), doesn't function correctly. It seems to skip a couple of channels. Also, if you are listening to BT music through the tablet, pressing the FWD and BACK arrows (to skip tracks), mutes the audio right after switching to the next track. I'm hoping this is a minor software correction.
G
Guy
See my post above.
The cable isn’t long enough to reach. They have to provide new ones unless you want to try to hack and splice it I suppose.
I am local to the shop and they reached out to me to see if they could use my 2018 Raptor 802a (sync3), to test the PX6 and troubleshoot a few issues. I previously had they older version and got fed up and returned it. After an afternoon with their engineers, we figured out what was wrong with the OEM navigation and why it wouldn't navigate correctly.
The Sync3 module is UPSIDE DOWN. Another piece of good news, is that all of us can fix it ourselves. When you flip the Sync3 module 180 degrees, you will only use 2 screws to secure it, rather than 3. The 3rd hole is just left hanging. I'm attaching a picture for reference. The screws are indicated by the red circles. Button it all up, and now factory nav works as it should.
