Pedal Commander! Awesomeness!
cao0215
Bought one and wanna install, but how to remove the plug on the gas pedal? So tight
it’s so simple, it’s counterintuitive. Don’t overthink it, you just depress the ‘tab’ and pull the 2 connectors apart.
Gilligan
dont horse it too much but if you kinda use the momentum of pushing the tab to help pull them apart all in one motion they usually disconnect right away. Once you try to take it slow and think about it one step at a time you're in for 5-10min of ******* around
R
Rick@FreedomMotorsports
Guest
oh, i pull up the red tab clip, and tried to release it, no go, any other clip except the red one?
Yes pull up on the red clip. On the side of the plug, on the red clip side you press in, it releases another tab. The red clip is just a security clip so the release tab is not accidently pressed.
