P0056, P0135, P0141, Driver Control Malfunction?
tyjova
Denver
Just recently I had the following error codes pop up on my 2019, 55K miles:
P0056 - H02S Heater Control Circuit (Bank 2 Sensor 2)
P0135 - O2 Heater Circuit (Bank 1 Sensor 1)
P0141 - O2 Heater Circuit (Bank 1 Sensor 2)
and then just a day or so later had the "Driver Control Malfunction" error pop up on start up along with none of the parking sensors working, can't change modes, and rides like a covered wagon. I've read threads on both of these issues and what may cause them, but before I go down the road of chasing gremlins, has anybody seen these happen at roughly the same time? I'm updated to the latest Sync and have the stage 2 Goosetune. I guess I can start replacing O2 sensors if need be for the codes, but as far as the driver control malfunction, it sounds like that has something to do with sensors in the shocks? I'd really love to avoid going to the dealer if at all possible, but if that's all that can be done I guess I'll bite the bullet....
FordTechOne
Detroit
Did you pull those DTCs with a generic OBD2 scan tool? With the Drive Mode errors there should be more than just O2 sensor DTCs setting. ForScan has the capability to pull DTCs from all modules.
T
tyjova
Denver
It was pulled through the cobb accessport, so you're right that I didn't see any other codes. I'll check into the ForScan!
T
tyjova
Denver
Alright, I was able to get my hands on a forscan today. Here's what I got, sorry for the blast of text:
===PCM DTC P0056:00-EC===
Code: P0056 - HO2S Heater Control Circuit (Bank 2, Sensor 2)
Status (-EC):
- DTC Maturing - Intermittent at Time of Request
- Malfunction Indicator Lamp is On for this DTC
- Test not complete
===PCM DTC P0135:00-EC===
Code: P0135 - O2 Sensor Heater Circuit (Bank 1 Sensor 1)
Status (-EC):
- Test not complete
===PCM DTC P0141:00-EC===
Code: P0141 - O2 Sensor Heater Circuit (Bank 1 Sensor 2)
Status (-EC):
- Test not complete
So nothing really new there since I already knew those ones. Then there is:
===PAM DTC B1B50:14-2B===
Code: B1B50 - Left Rear Inner Sensor
Additional Fault Symptom :)14):
- Circuit Short To Ground Or Open
Status (-2B):
- DTC Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Parking Aid Module
===END PAM DTC B1B50:14-2B===
===PAM DTC B1B48:14-2B===
Code: B1B48 - Left Rear Outer Sensor
Status (-2B):
===END PAM DTC B1B48:14-2B===
===ABS DTC U0146:00-68===
Code: U0146 - Lost Communication With Serial Data Gateway 'A'
Status (-68):
- Previously Set DTC - Not Present at Time of Request
- Test not complete
Module: Antilock braking system
===END ABS DTC U0146:00-68===
===PDM DTC U0140:00-08===
Code: U0140 - Lost Communication With Body Control Module
Status (-08):
Module: Passengers Door Control Unit
===END PDM DTC U0140:00-08===
===DDM DTC U0140:00-08===
Status (-08):
Module: Drivers Door Module
===END DDM DTC U0140:00-08===
===DDM DTC B1C09:15-48===
Code: B1C09 - Driver Left/Right Mirror Motor
Additional Fault Symptom :)15):
- Circuit Short To Battery Or Open
Status (-48):
- Test not complete
===END DDM DTC B1C09:15-48===
===VDM DTC C1A03:11-2F===
Code: C1A03 - Left Front Height Sensor
Additional Fault Symptom :)11):
Status (-2F):
Module: Vehicle Dynamics Module
Freeze Frame #1:
-EVENT_TIME: 623052 s (Tue Mar 26 15:35:50 2024) - Event time
-TOTAL_DISTANCE: 89344 km - Total Distance
-VSS: 0.0 km/h - Vehicle Speed
===END VDM DTC C1A03:11-2F===
===IPMA DTC C1001:97-68===
Code: C1001 - Vision System Camera
Additional Fault Symptom :)97):
- Component Or System Operation Obstructed Or Blocked
Status (-68):
- Test not complete
Module: Image Processing Module A
Freeze Frame #1:
-EVENT_TIME: 153530219 s (Sat Jan 13 10:45:36 2024) - Event time
-TOTAL_DISTANCE: 87210 km - Total Distance
-MODULE_VOLTAGE: 14.8 V - Control Module Voltage
-OUTDOOR_TEMPERATURE: -21 °C - Outside temperature
-VEHICLE_SPEED: 101 km/h - Vehicle Speed
-ECU_POWER_SUPPLY: 14.3 V - ECU Power Supply Voltage
-ECU_INTERNAL_TEMPERATURE: 12 °C - ECU Internal Temperature
===END IPMA DTC C1001:97-68===
===IPMA DTC B120C:13-28===
Code: B120C - Heater for Windshield Mounted Sensor
Additional Fault Symptom :)13):
- Circuit Open
Status (-28):
Freeze Frame #1:
-EVENT_TIME: 143236727 s (Sat Sep 16 08:27:24 2023) - Event time
-TOTAL_DISTANCE: 83021 km - Total Distance
-OUTDOOR_TEMPERATURE: 9 °C - Outside temperature
-VEHICLE_SPEED: 74 km/h - Vehicle Speed
-ECU_POWER_SUPPLY: 14.4 V - ECU Power Supply Voltage
-ECU_INTERNAL_TEMPERATURE: 11 °C - ECU Internal Temperature
===END IPMA DTC B120C:13-28===
Seems like a whole slew of other errors happening with the PAM (parking module), ABS, passenger door control, driver door control, vehicle dynamics module, and the image processing module. I could be totally off base here but I have to imagine that all those things can't just go wrong at the same time and there may be some sort of other electrical/fuse issue somewhere that leads to all that at the same time? Again, could be totally wrong on that. Thanks so much!!
Zeusmotorworks
Just in case you were unaware, you can purchase airgun pellets with a "tannerite-like" explosive in them. Won't fix anything on the truck, but every time one impacts you might feel a little better.
Well here's a quick follow up. Went to go check for possible fuse issues, etc and saw this. Looks like I have a much bigger issue than I thought......View attachment 449249
JAYZUS!
I need step out of the cave every once in a while. I can totally see these being a mood booster.
MurderedOutSVT
Brodozin
Georgia
Where does someone acquire such pellets.....
Asking for a friend
