Outlaw vs RPG vs Brenthel
jut619
theres a number of different set ups for a long travel kit for the raptor. done some research and found a couple like outlaw, brenthel, and rpg.
kinda just wonderin what everybody is using/ best set up for the truck.
please post pictures of the set up your running.
thank you
Jerryballs
Santa Cruz CA
still very new idea with raptors...These companies offer kits and the only one that has them available online for sale is brenthal. I know that RPG is doing testing now to release the kit later this year.
Outlaw offered a kit but I think you need to call for pricing. SDHQ makes one as well.
I personally am waiting for the RPG kit as they have developed a way of getting 19" of travel and keeping stock track width.
Good Luck
SPRSNK
I Void Warranties
Franklin, TN
Good Luck
The LT is not new and has been out for over a year. Outlaw does offer the kit. Of course you need to call for a price because it is highly customizable. Most people are not tube framing from the cab back (My truck, RSV 1). It is an option. We all know I have it and am an advocate for Outlaw. I have tested the ORP parts to excessive length and abuse including a roll over in which no one was hurt and the truck was driven off. They work and take the abuse.
Outlaw Raptor Long Travel Kit 18.5" 100% usable 4wd travel.
300M CV’s.
Chromoly Boxed lower arms and spindles.
Chromoly Spindle.
1” FK Uni Balls at all pivot points.
2024 Air craft grade billet aluminum L/T Upper control arm.
7/8 FK heim for upper arms.
Race upper shock mount with cadge attachment.
Dual double stitched limit straps.
7075 Air craft grade aluminum 1.5” tie rod.
Custom brake lines.
F9-11 race hardware.
Reinforces chromoly subframes.
Outlaw Raptor Long Travel rear under spring with shackle. 21" of Travel.
Deaver Raptor L/T Under sprung
Chromoly shackle.
Custom drive shaft
Chromoly rear end truss custom brace.
2” chromoly rear cage with 2 spare tire hold downs.
Outlaw Raptor 2” race legal roll cage.
Outlaw Raptor Chromoly Race Ft bumper.
Fiber Glass Fenders and bed sides
Currie Rear Axle 9", custom width
Shocks
King 2.5 10” Dual Rate race coil overs.
King 2.5 10” 3 tube Bypass front shocks
King 2.5 Bump Stop
King 3.0 16” 3 tube Bypass shock
King 2.5 Bump Stops
Interior
Ultra suede head liner covering the roll cage
Ultra suede custom dash covers and stitched
Custom carpet kit made for the roll cage
Sparco EVO 3 Xl seats x 4 (Run 3. 4th is for my daughters car seat and is modified to hold it in securely)
Sparco 5 point harness belts
ORP Hood Light Mounts
8 Vision X HID 4500.
6 Nitto Trail Grapplers 37 x 12.5 x 17
6 Method Race bead lock wheels 17”
Lowrance GPS
ICOM VHF Radio (PTT)
PCI Intercom System (VOX)
Parrot Bluetooth with Iphone 1-4 plug, USB plug
Sirius Sat Radio
1 Rear Mounted Center Seat
2 Pelican cases for storage compartments mounted to the frame on each side of the rear seat
Jerryballs
Santa Cruz CA
I guess what I meant was that not a lot of people are running them so he wasn't going to get a lot of feedback out of two people
Jerryballs
Santa Cruz CA
Sprsnk,
Also I really like the look of outlaws setup. It looks very clean and well engineered. I haven't seen many pictures I the rear, but is the bed cage integrated into the tire rack on your truck? And was the new rear axle mandatory with the spring under?
RPG
Orange County
Raptor Performance Groups long travel front kit was designed from the ground up to retain the factory width of the vehicle. This decision was not made just for aesthetic reasons alone, but to also ensure proper driving and steering dynamics of the vehicle. The average front and rear width of a Trophy Truck is about 90” wide, thus creating ruts in and lines in the desert that measure as such. We didn’t want to design a system that would have the front end so wide that it was driving outside of the driving line (groove) created by these big horsepower/wheel travel vehicle resulting in a vehicle that chase’s the groove as oppose to settling in and powering through it. This stock width front end mandate was also important for overall chassis dynamics. By retaining stock width in the front, the rear is still in line with the front end retaining the chassis balance designed from the factory. This assists in a predictable steering setup resulting in a very drivable truck.
The RPG long travel kit was designed to address the 3 following areas of driving dynamics for the Raptor.
1. Travel, we had a targeted goal of 19” of front end wheel travel and achieved every inch of it.
2. Improve steering response via pivot location, eliminate the bump steer that apparent in the factory Raptor and to eliminate the violent side to side motion through the steering wheel under hard breaking in breaking bumps
3. Anti-Dive. When you start getting into the high teen range of front end travel, nose dive tends to become a large issue under hard braking. Our upper J-Arm was designed from
the ground up to reduce large amounts of nose dive in the vehicle.
This leads to a stable and controllable drive both in the dirt and around town.
The RPG Long travel setup uses a Fox Racing Shox 3.0” (16”) Dual rate coil over and a Fox Racing Shox 3.5” (16”) External by-pass shock for all the damping control you will need with plenty in reserve. Control arms, knuckles, shock towers and all supporting hardware is 4130 heat treated, FK rod ends and spherical bearings is our preferred choice. Half shafts are 300M material, and all supporting brake lines, vacuum hoses and fittings are supplied to retain your 4wd system.
In the coming weeks we will be going into great detail about our system so everyone can see the little details that separate the RPG system from the rest. We will be taking extensive video for everyone to see and will be working directly with Fox to nail down the shock setup.
Our goal was to create a system that is daily drivable, yet crazy fast in the dirt. We didn’t just focus on a travel number; we focused on how we can make the entire vehicle drive much more dynamic in the dirt yet very livable for daily use.
vanilla_gorilla
NorCal (Sacramento)
Boom goes the dynamite... Out goes the double wide LT kits, can't wait for the details, pics and videos.
RPG, of course the kit won't be bolt on, modifications will be needed for the stock Raptor? Will you go into what the stock Raptor would under go when going with your LT kit? And maybe a ball park $?
408RCLB
Fort Lauderdale
ummmm... vvvvvvvvvvvvvv :secret:
sodrty
Lake Forest, Ca
Originally Posted by RPG - blah blah blah
you have come up with a very nice kit congrats, however I'm a little confused with your track width reasoning.. desert race vehicles are typically wider for a reason and just to clarify, 90" is on the low-low side for any trophy truck.
My truck has a front track width of 92" and it steers predictably AND handles great on road and off road, and it's definately "Driveable" because I drive it everyday.ha!
what you might find interesting is the engineers at Ford that were involved in designing
the Raptor actually wanted it to be WIDER... the reason the Raptor has the track width that it does, is simply because it is the widest they could make it while still fitting
on the standard F150 production lines.....
