802Avalanche
Do the UPR or JLT catch cans allow you to retain the engine cover?
I don't like the idea of drilling... Any other options?
Sent from my SM-G955U using Tapatalk
I still collect junk from the manifold vacuum, but if I had to do it all over again, I would have gone JLT. I don't think the extra vacuum under boost is all that necessary.
I got the UPR. It was under group buy, so it was discounted. I bought it under assumption it was plug and play, not knowing I had to drill the intake.
I had great concerns with drilling the intake. First, I did not want even a little hot exhaust air going back into the intake. Second, I did not want Ford to balk at warranty with a drilled hole around the turbo.
In the end, I installed it without drilling the hole and therefore not connecting the WOT line.
I called tech's at UPR and asked what would be the downside of not connecting the WOT line to the intake. All was said is no vacuum pull under boost. (Something like the stock line does and JLT does.)
The line is still attached to the can, but not the intake. It has a one way check valve to prevent air from going back into the can.
