Offsets and Rubbing w/ 37's
BayRaptor925
Nor Cal
Curious to know if anyone has direct experience running anything in the negative offsets with the stock 37" BFGs. I'm looking to order a set of Innov8 wheels and I'm interested in the -6 offset in 17x8.5. Planning on transferring the stock BFG C rated 37's to them. I don't want to do any trimming and I'm wondering if anyone has any experience with maximum offsets for these trucks without rubbing.
Also, is there any difference between the 37 and 35 trucks in terms of wheel well size or liners?
Thank you!
pnwobrigade
WA
I'd stick with +6 offset for Innov8 and that is entirely fine, negative offset can get touchy. Probably half the forum is running +0 as that is the most common offset and no issue with stock BFGs. Only when you get to the "true" 37's or run 13.50 wide versions does offset become slightly more critical.
hyrepower
Las Vegas, NV
I never rubbed with my KMC 17x8.5 0mm offset wheels with 37x12.5 BFGs. I have stuffed the front many times as well.
bubbaq
texas
Curious- what did offset Innov8 suggest to keep the 37 tucked as stock wheel set up? I’m looking to order them for the R.
StuPidaso
BFE
I'm running 17x8.5 -1 offset Titan T-AK1 with 37x12.50r17 toyo mt's and it rubs pretty bad even with a 1.5" collar. Stock BFG's wouldn't be an issue
Dutch19
Las Vegas
Just came back from Moab and I’m running 37 KO2’s 0 offset.
I think you might have a slight problem at full compression if you run -6 offset
Only one way to find out
McCarthy
Canada
37" KO2's on a +12 wheel, have stuffed the front and many times and no rub at all- 35 package truck.
