Syberspace
The light output of the factory fogs is not great. I am going to upgrade eventually... most likely to SR-M pro driving and driving diffused, plus a 10" bar in the lower grille.
That said, I did adjust each light up quite a bit. They are pointed at the ground from the factory and only light up a bright strip about 6-8 feet in front of the truck.
It is pretty easy. Takes a philips screwdriver. There is a slot at the bottom of each housing behind the bumper. If you are laying on your back looking up, turn clockwise to raise them
Sooooo much better now. I put the inner lights that are on Switch 1 a little higher than the outer ones. They actually project a decent distance, and are not even close to being an issue with glare for other vehicles.
