OEM fog lights and adjustment, much better now
bwkoop
AZ
Trying to adjust my 2023 stock foglights, the screws have some yellow on the heads assuming loctite? Cant get them to spin without stripping.
Burt
Auburn, CA
Is there an adjustment left to right or right to left or just the up or down adjustment?
77Raptor
Lancaster, SC
There is a slot at the bottom of each housing behind the bumper. If you are laying on your back looking up, turn clockwise to raise them
Sooooo much better now. I put the inner lights that are on Switch 1 a little higher than the outer ones. They actually project a decent distance, and are not even close to being an issue with glare for other vehicles.
How much of an adjustment with the screwdriver would you estimate you made? A couple full turns, a single full turn, a partial turn?
Syberspace
Syberspace
Pittsburgh
Can't remember... do it at night and you can see the cutoff line pretty easily. Just crank until they make a nice path slightly above the road. I did the left one slightly lower than the right one at first... then I upgraded the inner one to a SR-M pro driving. Huge difference.
lissailor
CT
I just did this and it made a big difference! Thank you.
On this topic, I put yellow lenses on the stock fogs (I think the outer ones). Has anyone wires both sets to the fog switch (or to Aux 1)? The light is sufficient for a yellow fog, especially if using all 4. I think it would be nice to put yellow lenses on all 4 lights and use them as fogs. Then put a light bar on another AUX switch for bright light driving.
insangsong78
cali
I just did this and the 4 fog lights adjusted to headlight level.
Visually the 4 fog lights seem to have equal output as the headlights.
While the fogs completely useless in stock levels, raised up (about 2 full turns) they light up the road very well.
MORaptor1
SW Missouri
I put some S2 Pro’s on last night. Major difference. I don’t need all 4 dogs on now and can resume using aux 1 for a different color or pattern of equally awesome S2 Pro.
Specialtyperformanceparts
When you say bumper options, you mean replacement bumper. I want to mount lights on Gen3 bumper but without drilling holes I understand there is no options as yet. True?
Actually there are...
So if you have a 2021-2024 with the standard, non modular bumper. We have these no drill mounts-
So the Main Mounts alone, allow you to bolt 2 LP4 or LP6 type lights on each side. Or a 50" curved bar.
Or, the crossmount option allows you to bolt that crossmount to the main mounts and a slew of whatever lights across.
If you have a 24/25 with the 37 or R package and it has the new modular bumper. We have these post mounts that can hold a pair on each corner with the single or 2 or 3 pairs (3 small/ 2 large) with the triple version-
and this is the crossmount version for that. Since it bolts direct to the bumper as well with the existing bolts
So you can really do anything you want here no drill with the OEM bumper.
That was the point when we designed these. To be able to use the stock bumper to add, but mot modify.
We also have any light you could possibly want to add-
and every plug n play harness combination you can imagine-
Let us know if we can help!
317/934/6778
info @spvparts.com
John
