Numerous Faults upon Startup Today
Bullishone
Definitely mention it. It's not like the radio acted up.. your truck went into limp mode, which on the freeway, as other have said, could be a major safety issue.
Sent from my SM-G955U using Tapatalk
It only happens at startup and usually related to something affecting the computer. So....
Sent from my Nexus 6P using Tapatalk
kandewinn
For sure, bring it up. I'm sure like most shops, they'll hook into OBD port, if it does not pull up a fault, they will have no idea what has happened, but maybe you'll get lucky and someone there may have heard of it happening before.
JetDriver480
JetDriver480
My only thoughts are if I have them look into it that I probably better remove my Pedal Commander and put the FORScan changed items back to factory settings... Was kind of hoping to avoid that simply because of my schedule/timing.
kandewinn
Don't know how involve Forescan changes are, do not have any, but the P/C is an easy removal for you as you know. Maybe just stop there????
I have a 2017 raptor just driving in sport mode and had everything say fault like
Collision Warning Not Available
Traction Control On
Hill Start Assist Not Available
Advance traction control disabled o my have 1400 Kms any answers ???
jakeO
Independence Mo
A possible cause would be a disconnected MAF sensor. Checking and cleaning that is something I do every oil change. It is an easy thing to check off the list as you debug the issue.
It will impossible for him to do that. The Gen2 ECOBooST run off of duel MAP sensors
FatBuoy
Anyone else seen anything similar? Just a one time deal maybe?
Mine did the same thing. All I did was pull over, pop the red clip on the connection for the BM open then closed, and it went away. No troubles since.
I tried this because the first time I installed the BM I had forgotten to close the red clip and got all of those errors.
Give it a shot if you haven't already.
Bullishone
Traction Control On
Yep you running a pedal commander or a boost Max?
Mcnawsty
Banned
Sounds like a bcm issue that others here have reported. Was anything from a loose clip on the plug to water leaking inside and made it go bad.
