the dry system has to fill the airbox and your o2 sensor. there is a delay from when you push the button until your o2 sensor is bombarded by the gas. at which point it adds more fuel. the time it takes to fill the area requires more time than the wet system. since the wet system mixes nos with fuel, the possibility of a puddle forming in the manifold arises. get a backfire in there and your motor is done. but the moment it leaves the fuel rail and is in the injector its ready to go. its also nice to have direct ports. cant do that with a dry system. it is definitely a quicker response. i run 1200psi in the bottles on the bike with an 80shot jetting. the timing has be retarded 2 degrees and my power commander can be adjusted on the fly. when i ran the wet system it definitely came quicker than my current dry system. most drag racers run a wet system, but i opted for the dry after having too many issues with the wet.
