Diverdown3
For those who have purchased nitrogen cylinders to do their own shock recharges, what size are you using? I'm guessing either 20 lbs. or 40 lbs.
Thank you. Very helpful.20lbs for me.. i charged about 10 shocks so far.
Thanks. I was wondering about that. Any idea how many lbs each 35" tire should take? Just trying to determine what all I can accomplish with 40 lbs. Obviously the shocks take very little.get a 40 and fill your tires after.
I use a standard regulator with a quick disco then hose and chuck to fill up tires. Set your reg to whatever you want the pressure to be.a 40 CF should be able to hit all 4 tires to like 35 psi and have some left. I have no ide how much is going into the shocks tho i guess its high pressure but low overall volume.Thanks. I was wondering about that. Any idea how many lbs each 35" tire should take? Just trying to determine what all I can accomplish with 40 lbs. Obviously the shocks take very little.
Thanks. I appreciate it.I use a standard regulator with a quick disco then hose and chuck to fill up tires. Set your reg to whatever you want the pressure to be.a 40 CF should be able to hit all 4 tires to like 35 psi and have some left. I have no ide how much is going into the shocks tho i guess its high pressure but low overall volume.
Kinda obvious. Others with experience already shared substantive responses.When it comes to nitrogen cylinders, the size you need depends on what you're using it for. If you're just doing some DIY stuff or need it for occasional projects, a smaller size like a 20 cubic feet cylinder could do the trick.
