ok the header install sucked. lots of cursing an beer drinking, hell i think i even made up some new curse words during the install because i got bored of saying the same ones so many times. i have scrapes on my arms from the elbows down because how tight it all is. the instructions SW provides sucked something awful. they need more pics and some tips. the only pics they had where black and white and not clear. everyone knows their instructions sucks as well as SW. they are working on putting out a better set....
even with the motor lifted and the starter out and the wheels off its tighter than a dolphins *******. luckily the manifold studs came out fairly easy. i knew i was in trouble when the manifolds were tough to pull out of place tho. getting the headers in was a treat. i dont even remember how exactly i got them in but it involded different angles and twisting and i think i may of stood on my head once or twice, who the hell knows i think i just got lucky. only advice here is make sure u have the bottom bolts in and leave just enough threads out to hook the header on it. other wise getting those bolts in is very difficult. also if u have a moroso oil catch can remove it. it gives u a bit more clearnce and viewing angle.
now as far as the header bolts, if u get locking bolts like i did(stage 8) put them on when u put the bolts in. my buddy said we should wait till we do some heat cycles then re-torque then do the lockers, well u need 2 hands to install the locking clips and once the engine is mounted back in and the starter is in u can get to some bolts to install the clips any more. u can reach them with a socket but not with your hand....FML...so i got more than half the locker clips on but some are just torqued and after i put some miles on it ill have to re-torque them, o well. o yeah dont miss a single step and go out of order when u re-install parts. i forgot to put the oil dipstick tube in and i dropped the motor back down and had the starter in and guess what....couldnt get the dip sitck tube back in. had to lift the motor and pull the starter out, put the dip stick tube back in and then put back the starter and drop the motor back in, yikes!
list of some things that will make life easier
all different lengths of ratchet/socket extestions, have some long ones like 18" or more
pivot sockets are a must!!
copper thermal anti-sieze
i did plug wire insulators to be safe
tie wraps to tie wires up out of the way here and there.
extra set of hands, remember that project u helped your buddy with, its time for payback
lots and lots of cold beer. if it wasnt for that i would of lost it multiple times
copper antisieze
as i think of more info ill follow up. any questions feel free to ask. hoping to get pics and vid up tomorrow night,
