Next Gen 21 Raptor Light Kits NOW starting to release.... Here is where to look...
pnwobrigade
WA
What's your take on say 4x Rigid SRM Driving (2,376 lumens each) vs 4x Baja S2 Pro (2,450 lumen each)? My understanding is the Baja are a bit truer output and the additional lenses options is a bonus. Could run one set with yellow wide cornering for fogs and have the other set installed on the Aux switch be a normal driving/combo set? Big question, does the Baja S2 look just a factory? Any larger photos you could share of the S2 in the factory bezels?
Second question - can you interchange lenses on the SRM Driving 3 LED models? As in, use the higher output 3 LED housing but utilize the SAE fog style factory lense. My thought being have one set driving and one set fog (if possible) but utilize the higher power SRM-Pro model for both. Not sure why Rigid doesn't offer this.
Specialtyperformanceparts
Well, it's personal preference really. On one hand, all the Baja S2 pro lights produce 2,450 lumens, where in the SRM only the Driving Pattern produces the 2,376 lumens. The Flood and spots produce 1,584 lumens. So to match the output of all the other Baja patterns in that size, you'd need to do all 4 in driving. I kind of like mixing up patterns for more coverage. So like a spot and a driving or a Flood and a spot or a flood and a driving, etc.
So on one hand, the SRM's in both driving patterns will look identical to what you have now with more power, you will have the same pattern like you do now. With the Baja S2's, you can pick 2.
As far as fitment, I think the S2's actually fit cleaner as we have them back a little more flush.
Of course I am a Big Rigid fan in a lot of their other light options, just not as much the SRM's. They are essentially 1/2 a D-series with exactly 1/2 the Lumens and 1/2 the LED's but are the exact same price as the comparable D-Series. Obviously the D-Series won't fit in this configuration.
pnwobrigade
WA
That looks darn near OEM+ and I like that a lot...4X S2 Pro I think would provide awesome supplemental light with nearly 10,000 lumens down low. 30" in the upper grill and would have a nice setup!
Yep, except Ford moved the shutters forward more, so the biggest we will be able to get behind the upper grille now is a 20" and a 10" still below.
John
pnwobrigade
WA
John
20" S8 or 20" OnX6? I have the S8 and Squadrons on my Can Am but could see the OnX6 being pretty awesome on the Raptor.
In the 17-20 Gen Raptor, Baja was able to get a 10" ONY6 in the lower grille, but not in the upper at all. They were able to get an S8 30" in the upper.
Now, Ford moved the active shutters FORWARD and closer to the Grille in both the upper and lower grilles.
Therefore, you can only get a 20" S8 in the upper and a 10" S8 in the lower. The ONY6 10" in the lower is almost 2" too deep, where it either hits the shutters, or if you bring it forward, it hits the grille and you can't put the grille back on. So, the only way you can get an ONY6 in the lower grille now is by cussing a rectangle in the grille so it protrudes through it.
We may look at an option to either add a frame and a template to do that, or a different grille in the future. Right now though, the S8 is the only bolt in option from Baja.
John
Here are the Rigid SR-M Direct Replacement kits and the Diode Dynamics kits.
Note: The Rigid SR-M has the same case/look (in the front. Mounting is different) so if you want the EXACT same look, then going with those, they will look exactly the same, except be more powerful. With this kit, you have the option of just upgrading ONE pair, or both. So for example, if you want to keep one pair of the low power DOT lights on the fog switch, and you want to put a pair of High Power driving SR-M's on the location for the upfitter switch, you can do that. Or, you can choose 2 pairs (which come with all the hardware and plug n play adapters) and swap them both.
Diode Dynamics have a white light, and an Amber backlight, somewhat like the Rigid Radiance. (Unless you choose amber lights and then they won't)
Syberspace
Pittsburgh
Interested in a Baja S2 setup... one set of Pro spot and the other amber driv
We just released 3 versions of our Rear light kits for the 21 model Raptor.
Baja Designs S2 sport or Pro
Rigid SRL Red Backlit
Rigid Radiance or Scene
If you follow this link to Raptor Light kit options, you will see these and new kits as they pop up.
Look very soon for lower light bar, upper grille light bar, A-Pillar and then replacement fog light kits to show up here...
Ask us any questions you may have!! Shoot us an email at info @spvparts.com
John
Liking this a lot... looking for an option for Baja S2 sport and pro mix. Assuming this can be done. I like the sport driving combo for an "SAE" like output, then having a Pro to light things up a little more on the back roads.
EDIT.... I just ordered the brackets... will make my own combo. Thanks for putting this together so fast!
