Next Gen 21 Raptor Light Kits NOW starting to release.... Here is where to look...
Specialtyperformanceparts
So the SDHQ mounts are a no go on the Gen 3?
They Bend IN to mount, the Antenna has moved from the fender to the cowl. So bending IN, hits the antenna in a Gen 3.
We will have our HD version done and ready to ship in the next few weeks. They will be on par and better in many ways over the SDHQ.
John
Littlefx4
John
Thanks. I’m all in on the pre-order as well.
All, thought you would like to see another update.
As I said before, we are hard at work. Not to just offer one option, but many. And we are trying to get them all out as soon as possible.
So, please know, this is NOT in place of a full size double or triple fog kit. Those are coming as well. However, for those that want another option simply reusing the factory housing and being able to replace the low power DOT lights in it with Baja Designs S2, Diode Dynamics SSC2 (amber backlit) or even higher power Rigid SRM lights. We have a solution coming for you soon. These simple mount plates will mount to the backside of your housings and allow you to mount any of those 3 types of lights to them retaining the same overall look, with more power obviously.
Yes, don’t worry. We will also have plug n play adapters so no wiring is required.
These, with the Lower Grille mount kits, and A-pillars, and Diode Dynamics Rear light kits will be prereleased for preorders hopefully next week for those that want to get them as soon as they get here.
Here are some pics-
3D1EEB1A-2F78-46AE-9D42-96666DED8486.jpeg5CFDC4BF-EC47-4773-9C5A-04ED179B8A24.jpeg2F426725-DADA-47BB-A6EC-01D53954A17C.jpeg6831118C-04E2-4BB8-A73D-667FB80B5971.jpeg9850D742-66BA-4C77-8D3D-0C4F14B29E30.jpeg
Syberspace
Pittsburgh
Here are some pics-
I like this option a lot... wasn't going to add a lot of additional forward lighting, and this will be a nice upgrade to the factory units.
Great.
So we are covering the bases with our new Fog kits.
We are planning to have 3 different kits.
1: Like pictured above with 4 small add on brackets for the factory housing and adapters to plug into the factory wire harness to the lights. That would use the 1.5x3" lights like the Rigid SRM, Diode Dynamics SSC2 and Baja Designs S2's
2: A 2 Light full size kit with the 3x3 lights like Rigid D-Series and Radiance, Baja Designs Squadrons, and Diode Dynamics SS3's It would have a close out front panel/cover
3: A 2 or 3 pair 3x3 mount similar to the mounts for the Gen 2 without a close out cover. However, if you do squeeze 3 lights in there, you won't really need a cover as the lights fill up the pocket pretty good.
So in order of complexity and price.... The add on small brackets will be the cheapest kit. Followed by the 2-3 pair triple mounts at about the same price as the current Gen 2 mounts, and the more complex close out panel type the most expensive.
jikjak
Canada
Great.
Does option 2 mean I could use a pair of squadrons and have a bezel around them for a factory look?
Will you be selling the mounting kits on their own for those of us that already have lights in hand?
