- Joined
- Jul 15, 2017
- Posts
- 1,280
- Reaction score
- 1,218
Good question.@Specialtyperformanceparts dumb questions, but the “A pillar mounts” come with 1 or 2 mounts? And the standard one also doesn’t require cowl removal?
See photo below of both final approved designs being produced.
So, neither will require cowl removal. Both are one piece designs so you don't need to assemble anything and that also eliminates week points where you bolt 2 pieces together.
Depending on where you want to run your wiring though, you may or may not want to remove the cowl, but it isn't required. You can run the length along the firewall toward the switches/battery.
Keep in mind though, the light duty one should only be used with small lights, like D-series, Squadron, S2'S SRM's and equivalent. 1-2lbs max.
If you want to put larger lights on like XL's, Rigid 360's in 6", etc, you will want the HD ones. Or if you plan to later upgrade to a larger light, you can be prepared with the HD version.
John
