Newbie first post!
AdamsPolishes
Welcome to the forum @dhanni848!
To remove the rear emblem, insert a small screwdriver into the little slot on the bottom, then carefully pull STRAIGHT back, and it should pop loose. If you pry up, or pull back at an angle, then the emblem connectors may break. Also, there is also a chance that one of the metal prongs on the plastic connectors was bent when installed, and it will break the connector. If it does not pull off fairly easily, then wait until you have a replacement emblem in case the current one breaks.
-Dan
mmaterni
Toledo Ohio
Welcome to the forum. There's always a lot of great tech info on here and those willing to help. Let us know when you figure it out.
dhanni848
dhanni848
Nashville, TN
Checked what seems to be the right fuse and it was fine. I checked the 10A in position 34. Maybe that sounds right?
I maybe should start a new thread in a different location too :(
Rookie
Fort Wayne, IN
Welcome!
freedommotorsports.us
Email: [email protected]
