Need steering rack adjustment tool
Canuck714
San Antonio TX
are you chasing slop in the steering wheel?
After tightening my rack slop, i discovered a leak so just replaced the rack . Guess what, still had some slop!!
Turns out most of my back and forth steering wheel slop was actually the steering shaft... For F-Sakes!!
The shaft has a collapsible slide with Teflon bushing where the 2 parts slide in and out.. Was completely worn out.
jackjare9455
jackjare9455
Longview, TX
History and update on this:
I was going down a neighbors driveway, which was a lot of hard gravel rocks and rough but small potholes, and I just felt it ALL through the steering column. I could feel some of it as "play" in the steering wheel, my hand was holding firm, but you felt slop underneath, if that makes any sense. I checked the tie rods and the rack, and I had no play there.
So, I made the adjustments and didn't feel it helped. However, I went back and re-adjusted again and I think it made a slight improvement in steering feel.
I think you are correct, that the play has to be in the shaft itself.
If I have my truck off, I can shake the steering wheel back and forth and hear an audbile "clank" noise. After tightening the "slack" in the gear box, I still hear the noise, but it is less audible.
I had some older chevy trucks that I had to replace the intermediate steering shaft to fix steering wheel clunk... I might look into replacing the steering shaft components, to see if that alleviates the issue, like you mentioned.
Canuck714
San Antonio TX
the shaft is cheap-ish.
I thought I got mine for just over a $100 a couple years ago.
Google steering shaft for your year and there will be options.
I still think there should be a roll pin securing the 2 halves. After a couple off-road excursions you can feel a little give in the Teflon bushing.
Metro Detroit
I feel like at this point cant you get one that is just a straight rod? or does this part allow the telescoping feature of the wheel?
n204life
Clackamas,Oregon
Same issue here I'm chasing down. Adjusted the rack and pinion tension spring to just where it bottomed out and it made little change. Still have slop. When I rotate the steering shaft by hand in the engine bay it seems from steering wheel to rack and pinion input shaft is 1:1. I can swear all my slop left to right is rotating at the r/p input shaft.
Wouldn't you be able to see the wear if your rotating the steering shaft by hand? Like if you shake quickly back and forth your see a wear point and essentially a clunk right? If the steering shaft u joints were bad you'd see it right by shaking?
I got to get a handle on this cause my bump steer is dangerous sometimes.
Members online
96,423
60,352
luis2017
