2023 Gen3 37PP-steering wheel thumping/tapping feeling.
New recaros
Colorado
Have you changed the power steering pump? Maybe the pressure control has an issue. If you were just hitting the set point, it would pulse the pressure.
JDMCTR00
JDMCTR00
Los Angeles,CA
These trucks don't have a PS pump. I have done all the testing and it's 100% the lower shaft. I have posted all my testing in this thread.
New recaros
Colorado
Ok, it’s electromechanical. That’s more likely your issue. Varying voltage or something
JDMCTR00
JDMCTR00
Los Angeles,CA
I understand what you are saying but I disagree due to the fact that I have done all the testing and I have video proof of this issue. You can clearly see what's going on in my videos and testing of the shaft. Additionally, Ford checked the steering rack and that was fine. This is a heat soak related issue into the shaft (always at the same time into my drive). A voltage related issue wouldn't cause the shaft to act the way it is. If you watch my videos and read through the posts you will see what i'm talking about.
New recaros
Colorado
I rewatched all, if the lower is not moving, as it looked in the video then the question is ,what’s moving the upper shaft or better said, what’s allowing it to move? What about the bearing or bushing support at the fire wall? I think you had one showing the steering wheel moving. I believe the upper portion of the shaft is supposed the be fixed horizontally to the fire wall.
I was trying to time the moment, looks very much like a pattern. 1sec down and about 3 seconds up. I still think the rack has a servo motor limit switch or torque calibration issue. Probably not adjustable in this, but voltage signals could be monitored.
JDMCTR00
JDMCTR00
Los Angeles,CA
The lower shaft pulls out and pushes in during body/frame movement. The firewall bearing has been replaced already. The shaft coming out of the firewall is a solid part other than the "rag/rubber joint" under the dash. The lower shaft is moving if you look at the yellow rubber boot area. You can also hear the shaft thumping/binding in the videos. I took the shaft out and pulled it in and out while it was cold and it was smooth. I heated it up as it would while on the truck and it started to get real tight and it was binding.
Also keep in mind that all this thumping i'm talking about happens without any steering input/movement. There is a reason why Ford added the black boot/shield around the lower shaft for the 2024 model.
Post 28 & 29 clearly show the issue. Turn up your volume you can also hear what i'm talking about. Post 40 also shows when the shaft is cold and when it's hot.
New recaros
Colorado
Bandaids or fixes. I suggest you put a dial indicator on the rack input or the closet ujoint to the rack, I think you find it is moving back and forth just a bit. That movement is torquing the shaft towards the steering wheel. The spline is trying to absorb the torque. I will leave you alone, but that movement has a pattern not caused by steady heat.
JDMCTR00
JDMCTR00
Los Angeles,CA
Your information is valid but in this case that's not what is happening. The movement is not side to side jerk it's in and out towards the firewall/steering wheel. The proof is in the bench testing when the shaft was tested off of the truck while cold/hot. The pinion gear coming out of the rack is not moving in and out in a way to cause this much movement into the lower shaft.
New recaros
Colorado
The piñon does not need to move up and down, twist is what you’re looking for. The twisting or turning like a clock, could be adding torque the shafts, then it releases and repeats. Very typical servo response..
This reminds me of a thing that happened after a million dollar steam turbine generator OH. We totally OH both units, when put on line it started to vibrate within 1mil of shutdown, we rechecked the alignment a couple times, did lift checks, checked for soft feet, no help. The GE Rep figured it out, somebody way overfilled the coupling with the wrong lubricant. The pressure inside the sealed coupling was the issue.
JDMCTR00
JDMCTR00
Los Angeles,CA
I'm not having a twist on the shaft, it's the in/out pull on the telescoping shaft that's binding under heat. I have done all the testing on the shaft itself. If it was twisting the steering wheel would also have a twist or slight turning motion. The shaft is shafting itself lol.
