Can a 35x12.50 r 17 Nitto or Duratrac fit as a spare underneath? I am hopeful the answer is yes but do know they are just under 1/2" bigger than the stock 315s.
Thanks. I just thought I would check as the 315s are 34.4 and the duratrac and nitto 35s are 34.8a 35 inch tire is 35 inches tall so it will fit under the bed just like the 35 tire that comes from Ford. 12.50 is the tire width and under the truck, this translate to how lower it hangs. OEM wheels are 12.7" so it hangs higher.
I hope this makes sense.
Thanks all. Appreciate all the great recommendations.
_______
I'm still between:
Goodyear Duractrac that weigh 63 lbs and are E rated
or
Toyo Open Country RT which are 73 lbs and F rated
_______
I want to go Toyo but adding 10lbs of unsprung weight per tire is hard to justify.
Well....I found a tire I would NEVER go with.... being a HEAVY ASS, OFF-ROAD, MUD TIRE.
Did you bother to read the first post before attempting to make a positive contribution?
"The 35X12.50R20 General Grabber has a diameter of 35", a width of 12.5", mounts on a 20" rim and has 594 revolutions per mile. It weighs 81.8 lbs, has a max load of 3195 lbs, a maximum air pressure of 65 psi, a tread depth of 18/32" and should be used on a rim width of 8.5-11".
