thegrays
Livewire TS with 5 star tunes
The lights were on that’s the error that started the sagaOk, did you update the firmware?
Note: Things to do when tuning is to not have anything running, no lights, no radio, no open doors.
You can call SCT and have them go on your PC remotely and check everything with the Livewire TS
Communication DTCs can set because of the corrupt tune. Before dropping $1000 on a PCM, you may want to have the dealer try and recover the PCM by following General Service Bulletin 21-7122. There is a process to reflash the PCM to the factory calibration.I’d say the ecu is definitely fried, I received 4 different CEL regarding miscommunication to the ecu.
How much would this cost, plus I’m not trying to have the truck sit inside the dealership for a week or two just for an examination. Although im almost certain the trucks ecu was fried, are there key symptoms of a fried ecu? I’m on stock tune right nowCommunication DTCs can set because of the corrupt tune. Before dropping $1000 on a PCM, you may want to have the dealer try and recover the PCM by following General Service Bulletin 21-7122. There is a process to reflash the PCM to the factory calibration.
I have tried but they didn’t pick up only can email but then again they didn’t give a straight up answer I will try later later todayDid you call SCT, they will help you with why it's not communicating.
I definitely updated the device before installing any tunes, and the voltage sits around 14Have you plug it back in to your PC and run the https://derivesystems.helpjuice.com/136470-info/346005-downloads
If you didn't update first before loading the email Tune from 5star, I would suggest removing the Tunes from the LWTS then doing the updates and then reinstalling the Tunes.
Plus, you never answered if the battery is up to par.
If you turn the key to the on position (not running), the battery needs to be above 12.7, if it's at 12.7 you will need to use a charger when tuning.
