Need Help Finding Valve Body Shift Sequence
KingSVTRaptor
KingSVTRaptor
Pacific Northwest
That’s correct. As-Built does not contain the transmission main control solenoid strategy.
So I got the truck home last week and had a chance to drop the pan today. These are the pictures I snapped from the underside of the valve body. I’ve noted a couple of things. Primarily, it appears that the shift sequence for the valve body is stamped exactly where you’d expect it to be. Secondly, I noticed that there is a FoMoCo stamp. The service advisor I was speaking with swore up and down that the original valve body had been replaced with a non-factory unit and that was why they were unable to see or retrieve the appropriate information from it. Did they need more than just the information in the attached pictures to complete programming?
FordTechOne
Detroit
That’s the The 13-digit solenoid body strategy number. There is also a 12 digit solenoid body ID. I suspect that with the PCM being replaced and the transmission service tag missing, that’s the step they’re getting hung up on.
KingSVTRaptor
KingSVTRaptor
Pacific Northwest
Thanks for the info. The way I understand it is that you only need one or the other. Once you enter one a file is downloaded from the Ford server containing the other. I’ve linked a video below for reference.
