Need help with new pcm
MTF
Celebration, Florida
Ok, did you update the firmware?
Note: Things to do when tuning is to not have anything running, no lights, no radio, no open doors.
You can call SCT and have them go on your PC remotely and check everything with the Livewire TS
thegrays
thegrays
Arlington, Texas
The lights were on that’s the error that started the saga
MTF
If your voltage is too low when tuning, weird crap can happen.
I suggest using a trickle charger on the battery when trying to Tune.
And make sure you carefully close the hood for the start safety switch.
FordTechOne
Detroit
I’d say the ecu is definitely fried, I received 4 different CEL regarding miscommunication to the ecu.
Communication DTCs can set because of the corrupt tune. Before dropping $1000 on a PCM, you may want to have the dealer try and recover the PCM by following General Service Bulletin 21-7122. There is a process to reflash the PCM to the factory calibration.
thegrays
thegrays
Arlington, Texas
How much would this cost, plus I’m not trying to have the truck sit inside the dealership for a week or two just for an examination. Although im almost certain the trucks ecu was fried, are there key symptoms of a fried ecu? I’m on stock tune right now
MTF
Have you plug it back in to your PC and run the https://derivesystems.helpjuice.com/136470-info/346005-downloads
If you didn't update first before loading the email Tune from 5star, I would suggest removing the Tunes from the LWTS then doing the updates and then reinstalling the Tunes back onto the LWTS.
Plus, you never answered if the battery is up to par.
If you turn the key to the on position (not running), the battery needs to be above 12.7, if it's at 12.7 you will need to use a charger when tuning.
thegrays
thegrays
Arlington, Texas
If you didn't update first before loading the email Tune from 5star, I would suggest removing the Tunes from the LWTS then doing the updates and then reinstalling the Tunes.
I definitely updated the device before installing any tunes, and the voltage sits around 14
