Hi - I installed an ADD bolt on bumper the other day. Everything seemed to go well; I relocated the ACC module with the Bajamod. Ran to Starbucks to show off the bumper and noticed the CEL. The Ford Pass app shows 8 alerts, the first being:
"The powertrain control module lost communication with the vehicle active grill shutter module for a period of time. Additional alerts may accompany this alert when this fault is present."
And they sure did. The additional 7 alerts referenced the cabin heater coolant pump control circuit, the engine coolant bypass valve control circuit and its associated wiring, the A/C control circuit and its associated wiring, the engine cooling fan control circuit, the charge air cooling fan, the turbocharger/supercharger control system, and the engine oil pressure control solenoid.
I took the truck to Advance Auto and they saw only one fault code: P0034. They cleared the code for me and it came back on the next start. I can definitely notice the truck driving differently, ie less power. It's not like gimpy, but certainly different. I have a feeling it all ties back to the lower shutter motor that I zip tied per the instructions. The motor is definitely plugged in as I can access it without removing the ADD. But, I plan to remove the grill tomorrow and get back in there and see if maybe I forgot to plug something else in that I can't see. Wanted to start this thread in the meantime to see if anyone ever experienced anything like this and/or could offer any advice.
Thanks in advance!
Jesse
Thanks in advance!
Jesse
