MPT Tune Version 4
Spartan1
Mars
I emailed my stock tune to MPT after the update and the tune does in deed need updated. I paid the $25 and am waiting for the updated version to come back. I can't imagine there is much time involved in adjusting it since the fee is only $25
I just got the update from my dealer as well and sent the $25 to MPT, re-read the new stock file, e-mailed it to them, and re-installed the MPT tune. While I was at it I finally had them remove the auto start stop feature. This by itself is worth the $25 I have come to realize. They said that the speed limiter is automatically increased. I had been using the 93 PRX tune and went with the performance / tow tune for this install. I would describe this tune as while still very powerful different than the 93PRX. She feels smooth as silk now. I'm not sure if it is the update or the different tune.
03'Darin
Harrisburg Pa
Not a lot of effort, but how many people are in front of you in their queue
That's probably true
I think its the update that makes the big difference. I'm pretty sure the tune just does multiplication off of the factory programming. So it wouldn't have any affect on the issues that the factory programming had.
Spartan1
Mars
I think that you are correct. I definitely recommend that everyone with a 2017 especially those with a tune have this ford update done at your dealer. The transmission shifts much better afterwards. I have a feeling that this is especially true if you have a tune. It is definitely worth $25 and a little time.
03'Darin
Harrisburg Pa
I've driven my truck for a few days now and probably 150 miles since the update was done. Yesterday I got my updated tunes back from MPT and loaded the 93PRX back in. The truck works GREAT now! Finally I should say!!
Tranny shifts like you'd expect it to and the hesitation/stumble is pretty much gone!
You guy who have done the Ford TCM update -
did you have any trouble getting it?
It took me 2 visits to get the factory update and I agree it was worth it.
1st pass with the s/a : please update the pcm/tcm with the current files, ... she’s 18 months old and I know there are updates.
got it back and it said “up to date” when questioned, the tech did nothing, just checked it and apparently whatever it comes with is good enough.
2nd pass: Update the pcm/tcm. I don’t care if it’s “up to date, hook it up to the machine and load the newest”.
- they call back and say they won’t unless there’s a warranty concern. I had to think on the fly and said ‘funky shifting and odd sounds at startup’ - that worked. I wouldn’t say I have those symptoms but I will say the shifting was lazy.
afterwards, much, much improved
03'Darin
Harrisburg Pa
I work for a Ford dealer so it's no problem for me getting it done. But I did have legitimate issues with driveability of the engine and trans. There is only 1 update but it does both trans and engine updates.
There are about 4 different driveability concerns that all fall under the update.
Blown00gt
Arkansas
Out of curiosity when was this Ford update created? My Raptor was built April of '18. Would I want to look into this?
icecoldak
Can you list these Concerns, so that we can walk in their and then should have no problem getting the update without allot of hassle--thanks
Can you post the TSB, or the Number as well
03'Darin
Harrisburg Pa
Sorry i missed this when you posted it.
18-2079
2017 F-150/Raptor - 10R80 Automatic Transmission – Harsh Or Delayed Shift Concerns And/Or Illuminated MIL - DTC P0711 - Built On Or Before 1-Aug-2017
Some 2017 F-150/Raptor vehicles equipped with a 10R80 automatic transmission built on or before 1-Aug-2017 may exhibit harsh or delayed shifts and/or an illuminated malfunction indicator lamp (MIL) with diagnostic trouble code (DTC) P0711 stored in the transmission control module (TCM). Reprogram the powertrain control module (PCM) using Integrated Diagnostic System (IDS) or Ford J2534 DiagnosticSoftware (FJDS) release 108.04 or higher. Make sure you are connected to the internet when entering module programming to obtain the latest updates. Calibration files may also be obtained at www.motorcraftservice.com.
See
TECHNICAL SERVICE BULLETINS
18-2160
2017-2018 F-150/Raptor, 2018 Expedition/Mustang/Navigator – 10R80 - IlluminatedMIL – DTCs P0741 And P1744 – Built On Or Before 20-Nov-2017
Some 2017-2018 F-150/Raptor, 2018 Expedition/Mustang/Navigator vehicles equipped with a 10R80 automatic transmission and built on or before 20-Nov-2017 may exhibit an illuminated malfunction indicator lamp (MIL) with diagnostic trouble codes (DTCs) P0741 and P1744 in the powertrain control module (PCM) or transmission control module (TCM). This may be due to a sticking torque converter clutch (TCC) valve in the main control valve body assembly. Follow the Service Procedure steps to correct the condition.
See TSB for complete details
10R80 Automatic Transmission – Harsh Or Delayed Shift Concerns And/Or Illuminated MIL - DTC P0711 - Built On Or Before 1-Aug-2017 18-2079
02 March 2018
Model:
Ford
2017 F-150
Issue: Some 2017 F-150/Raptor vehicles equipped with a 10R80 automatic transmission built on or before 1-Aug-2017 may exhibit harsh or delayed shifts and/or an illuminated malfunction indicator lamp (MIL) with diagnostic trouble code (DTC) P0711 stored in the transmission control module (TCM).
Action: Reprogram the powertrain control module (PCM) using Integrated Diagnostic System (IDS) or Ford J2534 Diagnostic Software (FJDS) release 108.04 or higher. Make sure you are connected to the internet when entering module programming to obtain the latest updates. Calibration files may also be obtained at www.motorcraftservice.com.
Warranty Status: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
Labor Times
Description Operation No. Time
2017 F-150 3.5L GTDI: Retrieve DTCs And Reprogram The PCM (Do Not Use With Any Other Labor Operations) 182079A 0.3 Hrs.
Repair/Claim Coding
Causal Part: RECALEM
Condition Code: 04
Service Procedure
NOTE: ADVISE THE CUSTOMER THAT THIS VEHICLE IS EQUIPPED WITH AN ADAPTIVE TRANSMISSION SHIFT STRATEGY WHICH ALLOWS THE VEHICLE'S COMPUTER TO LEARN THE TRANSMISSION'S UNIQUE PARAMETERS AND IMPROVE SHIFT QUALITY. WHEN THE ADAPTIVE STRATEGY IS RESET, THE COMPUTER WILL BEGIN A RE-LEARNING PROCESS. THIS RE-LEARNING PROCESS MAY RESULT IN FIRMER THAN NORMAL UPSHIFTS AND DOWNSHIFTS FOR SEVERAL DAYS.
NV997tt
That ****** me off. I just took my truck in to get recalls done and specifically mentioned the transmission hard shifting and dabs delays that almost render sport mode worthless. The said there was noting more current. I’ll uave to look but bet my truck built close to then as I bought it in December 2017. Mine is noticeably more rough than a couple buddies raptors as well as the one I drive at assault. Perhaps I need to push harder and or on a different dealer. Really sucks too because as soon as I left the dealer I came home and installed flash tune.
