- Joined
- Feb 16, 2017
- Posts
- 1,781
- Reaction score
- 1,124
That’s good info.
Here are some tidbits that may or may not be helpful to you.
I can tell you the maximum allowed boost is decreased slightly over stock on an MPT 93 PRX Tune.
From what I understand the ecoboost has a tough time with preignition and detonation and the limits to tuning is as much about running into detonation, particularly under load, than it is about the limits of the turbos or the fuel system.
Lars from Gearhead says he has a unique approach to tuning where he drops the boost back to the mid 17s and the ECU timing adjustments are made on the fly by adjustments that he makes to the predictive strategy.
There is an issue with adaptive cruise and tuning. It has something to do with throttle position and torque management in relationship to the computer making throttle adjustments to keep pace with the car in front. Less of a problem for 17’s than on 18s, but I had it happen with 5 star tuning on my 17, but they had super aggressive drive by wire settings.
Just all food for thought.
Yeah, that's about right. The max boost runs around 17-19psi at WOT. I've seen as high as 19.6, but the max boost seen depends on the Torque/Load targets, and it (boost/MAP) changes with the temp/air density. The ecoboost ECU doesn't target boost. It is as required to hit Torque/Load targets, but MAP has a "desired" value as requested by the pedal input and a max allowed value. They won't lay it all out in detail, but MPT (and the other "tuners") set the Torque/Load targets and the MAP max allowed a bit higher than stock and the max MAP allowed is usually attained. Then the throttle closes/adjusts to keep the boost at max allowed while still targeting the Torque/Load target. Even though the throttle is modulating in opening area, the thrust you feel is consistent due to the Torque/Load/MAP targets being relatively steadily maintained. Make sense?
