Morimoto Announces NEW 2nd Gen XB Headlights for Gen2 Raptors
DetTigers
Michigan
Which harness did you receive? You stated you received the correct harness the first time, but it was not. Are you sure you received the right harness the 2nd time? Again I'd recommend you contact the dealer you bought it from for assistance. You did not buy the lights from us so I can't verify what you actually received. Nor can I verify how you have everything wired up. There are certain things you have to remove on the Raptor installation in order for it to work correctly.
I have the harness in the picture you posted. You know the blue Raptor in the Morimoto press release video? That also has the hyper flash issue...
melvimbe
I may have missed it, but I only see the turn signal display at around 20s into the video. Is that what you're referring to as hyper flash? That looks like normal sequential turn signal light to me.
DetTigers
Michigan
The hyper flash occurs inside the vehicle. The turn signal indicators flash rapidly as if a light is out.
melvimbe
Then how do you know the truck in the video has the hyper flash issue? It's not in the video, so I assume you found out some other way. Did you get that info from your vendor or Morimoto directly? Just trying to figure out if this with your setup, your truck, something that can be avoided....or if it's an issue with all headlights and harnesses?
TK85
I had some issues with mine and was told by morimoto to tap into a different fuse than what was in the directions. The start up works but when in auto mode everything shuts off when shifting into drive during daytime
TK85
Are the headlights supposed to turn on in auto like the oem leds or are these morimotos just have the amber strips come on during daylight
Members online
96,139
59,972
23UniFordicorn23
