Moon roof rubber gasket seal maintenance, what lubricant?
Donmatteo
Santa Clarita / Coronado
Also, be careful with the lube when you're putting it on. That shit gets EVERYWHERE so take your time.
Also, before you open your moonroof, open it to vent and then close it and then open it. Do that once a month and lube once a year and you're going to be fine.
The moonroof has pretty much become a maintanance item.
There was a tsb about it awhile go.
Monte87
Monte87
NY ******
Thanks for reply and 411. Especially the advice on opening vent 1st, then roof 2nd..
Let me ask you this, the grease you listed is the only item? in the video he uses a lubricant drop? Do we use both or just grease? Just making sure..
Thanks Anthony
Donmatteo
Thanks Anthony
just the grease is needed. make sure and do the track as well.
BoostCreep
SoCal
The Krytox grease is what Ford recommends. It’s expensive but the tube will last you years. As others have said doing this as a maintenance item is key. Follow the tsb, use a microfiber and alcohol to clean then the grease. I fold a thin microfiber over a credit card and slide that between the body and moonroof, works well.
Finally, when I’m done I sage the moonroof every 6 months for good measure.
Kyle@Apollo-Optics
San Antonio,TX
Thanks Anthony
Yes every time before I open it, I do the vent also. Q-Tip is the way and go slow.
Monte87
Monte87
NY ******
Hi boost!
I'm gonna do that!! Do you slide the credit card and microfiber w grease on fixed glass as well??
Btw, what is "sage" the moonroof? Lol
Thabks Anthony
BoostCreep
SoCal
Hi boost!
Thabks Anthony
Yes, the microfiber around a credit card I think is what’s actually suggested in the tsb, and is the best way to get the rear fixed panel (alcohol on the towel first, then once clean put the grease on a clean part of the towel).
96,328
60,221
tmaltba
