Todd Turbo S
How many milled on yours? Do you see visible oil leaks? I don’t have any oil leaks.I have a 2019 and I am taking it in tomorrow to get new valve covers installed due to excessive oil consumption.
Not trying to scare you or say it is the valve covers at all, but others did mention they didn't see any oil there and the dealer ended up changing the valve covers anyway (saying they were leaking), along with that tsb repair. I guess just watch it at the next oil change and see how it is. It's not severe anyway, there's still oil on the dipstick, you shouldn't lose sleep at this point.How many milled on yours? Do you see visible oil leaks? I don’t have any oil leaks.
Hi All
I have a 2020 with 5,800 miles, at 1,000 miles, I changed the oil using Amsoil 5w-30 100 synthetic signature series. I also use their oil filter. I have a dual catch can and was checking to see if there was any oil and decided to check the engine oil. I found the dipstick read slightly below half. There was very little oil in the door catch can, not even enough to mention. Is this normal for a Raptors to burn oil? I did a quick Google search and read that the oil level should be at the halfway mark between the two dots on the dipstick. Anybody care to comment?
Hi All
ThanksNot trying to scare you or say it is the valve covers at all, but others did mention they didn't see any oil there and the dealer ended up changing the valve covers anyway (saying they were leaking), along with that tsb repair. I guess just watch it at the next oil change and see how it is. It's not severe anyway, there's still oil on the dipstick, you shouldn't lose sleep at this point.
Thanks for chiming in. It will be interesting to monitor our oil consumption. I change my own oil, so I’m wondering if Ford what are you been consider monitoring my oil consumption and less I allow them to change the oil at the next interview and then monitor from thereIt is funny that you posted this, I have a 2020 like you with 3500 miles. I changed my oil/filter at 2500 miles and switched everything over to AMSOIL. I checked my oil this past weekend and my dip stick was low like yours. My driveway is on a slant/hill, so I can't really check the oil while at home. I put half a quart in it and will see if I need to put more. AMSOIL is very difficult to burn off, which is why it is great for turbo applications. I was shocked to see it so low because I drained a full 6 quarts out and know I put a full 6 quarts in.
Did you drive the vehicle to warm everything up, and let it sit for 15 minutes before checking?
I have about 25K miles and no visible oil leaks. I read the TSB and if there are visible oil leaks, they say the Technical Service Bulletin does not apply.How many milled on yours? Do you see visible oil leaks? I don’t have any oil leaks.
