BentToast
Are you drunk Pirate? From the warranty agreement exmple
Its basically the same drivetrain warranty Ford gives.Engine Components:
Covered: Pistons, piston rings, piston pins, crankshaft and bearings, connecting rods and bearings, camshafts and bearings,
timing chain and gears, intake/exhaust valves and seals, valve springs, oil pump, push rods, rocker arms, rocker arm shafts, and
lifters, SUPERCHARGER and Supercharger kit components. If a failure of any of the above parts damages either the engine
block or cylinder heads, a remanufactured long block assembly will be provided up to the maximum coverage of $5000.00.
Non-Covered Any engine components not specifically listed, including but not limited to, electrical components, seals & gaskets,
polished finish on SUPERCHARGER – as well as parts, filters, fluids etc., that are required to be replaced as a part of your
vehicle’s normal maintenance schedule as published by the manufacturer.
Transmission Components:
Covered: All internally lubricated parts within the transmission.
Non-Covered: Failure of related parts external to the transmission which may cause a transmission claim including, but not
limited to, electrical components, seals & gaskets, transmission coolers, levers, controls, etc.
Rear Axle Components:
Covered: Rear axle, ring gear, drive pinion, pinion shaft, side gears, bearings, bearing cap, washers, slinger, axle shaft, housing
and housing cover.
Non-Covered: Seals and Gaskets
