Long Tube Headers and Engine Light
Wilson
South Dakota
I put on SW LT and the dash light never came on. I took the cat's off and shut the o2 censer off. I have the cat's for sale
---------- Post added at 05:04 PM ---------- Previous post was at 05:02 PM ----------
I forgot did you get them on and if so where is the sound clip I'm still looking so might be on you're posts.
vipergts
new york
won't pass inspection
hey guys, i'm in new york and finally going for my emissions test and she won't pass , swheaders , highflow cats and a 5 star tune, put the stock tune back in drove 20 miles and got the cel , code say's front 02 sensors too slow, i forgot to write the code # down but remember it saying , fronts to slow, so i think i'm screwed, changed the oil, 200 miles ago, air filter is clean, and monitors are throwing the light, any suggestions or do i have to go back to the stock exhaust, this sucks, i read a thread a while back on jim d'amore in new jersey may have a fix , has anybody spoke with him??? i will call him on monday and see what he say's.
Cleave
Oxnard, Ca
Tune won't help if the air-fuel ratio sensors are already switching slowly, basically you need new sensors and then run the stock tune while it's getting tested, unless there's a way to temporarily revive air-fuel ratio sensors, you could just get a new set of air fuel ratio sensors, swap them in for testing then take them back out and put the bad ones in for driving until you need to test again
IRONMAN
Well-Known Member
MICHIGAN
Put the tune back to stock and drive it so the sensors reset
He did.
I heard something about an "Anti spark plug fouler" screwed onto the O2 sensor then that screwed into the cat would trick the system.
Not sure if that's works or not.
vipergts
new york
the code i am getting off the sct is PO153, o2 [ho2's2], ckt slow response cb2s1,that is exactly how it reads on the tool. sent that over to mike at 5 star ,waiting to hear back on a possible fix, any suggestions ???? would be great thx guys
