ok got it. so does the rear one measure ratio or just an amount of gas. if its ratio then it wont work. if its look for aa amount then this will work. when i google it tons of info comes back with it working
The ECU is looking for the difference between the front & the rear O2 sensors, so I would assume the readings are comparable in that format. Anti-foulers are meant to put a spark plug out of the cylinder to prevent oil from "fouling" the spark plug & can be modified to do the same for an O2 sensor, but it will still read the exact same as it did before.
I run O2 sensors 3 feet outside of the exhaust pipe, on my dyno & get the exact same reading as if they were installed in the pipe directly.
I am certain a 1" spacer will not improve/fool the reading at all.
