CoronaRaptor
It's getting better. Damn, I'm learning a lot on this thread. Very informative information from all parties involvedDamn this is some good reading. How did I miss this thread????
Jim,
I am confused on this. If you state the stock pump is good to 550, it wouldn't be out of fuel, so why would an upgraded pump show any different data below this point? If the stock one won't pressure drop, neither will an an aftermarket one of higher flow.
Also, I am even more confused on the comment about a single pump versus a twin pump. Are you saying that a higher output single pump isn't an upgrade? That's how it reads, and I certainly know that isn't possible. Volume is volume, no matter if it comes from one pump, or two. A single 500lph pump will support essentially the same as 2 255 pumps. So if you can do the job with one drop in, you should. Now, there is of course a limit that you would hit with our single pump, and then we run a BAP (we have been doing them for 14+ years, and in 14+ years have only had 3 failed units). It's all in how they are installed.
I would really like more insight into this logic. as it really does nothing for the confirmation or counter argument about our setup.
If you aren't out of full, the pump won't help. Just like bigger fuel injectors don't add horsepower or help if you don't need them, this is no different.
Jim,
Your right the truck wasn't running out of fuel, or wasn't going to even on the stock pump. We've seen that happen and its around 560+ RWHP. We usually limit our customers to 550 RWHP for safety sake. We've never tested the Livernois pump to that point. When we tested it at 535 RWHP (approximately) on MetroNYC's truck we weren't at the limit of the stock fuel pump but we noticed the fuel pump duty cycle to be right about what we would see with the stock pump. That leads me to think it wouldn't support any more power than the stock pump.
Now we have only worked on 1 truck in person and 2-3 mail order with this fuel pump upgrade. Since Livernois has obviously done more can you explain to me what the difference is between the two pumps, how they each flow, their rate, and why it's actually better? Do you really not need to make any changes in the tuning? Because all you can do is raise the alternator voltage to get more output from the pump, same principal as a boost a pump your just driving it harder than design. We've never installed a BAP, we've had Zero related Failures in 20 years doing business.
I understand bigger fueling components won't add power, but what they will do is usually relieve duty cycles. I did not see a change from the Livernois pump to the Stock pump on this 1 truck.
JimIII
I think the problem Metro is having with his fuel gauge is most likely the fuel level float is hung up or catching on something when the fuel level drops. Which should not hinder the fuel pump's ability. Since we didn't install it I can not say for sure what's going on but it's the likely cause.
I wanted to sell this pump to my customers as an upgrade. When Metro brought his truck in we wanted to see an improvement. With the little information given or technical data to support it I had to make a judgement call after seeing the way his truck performed. Until I see evidence to support otherwise I tell all my customers we are leaving them at a maximum of 550 RWHP due to lack of fueling ability.
Sounds like you and @Livernois Motorsports should work out them sending you a unit for testing. If you're happy with it, you can sell/recommend their setup, if not, you can send it back.
EDIT: and @Livernois Motorsports can send me their heads/cams to test... and I'll never send them back![]()
Is it just me, or does a person lose a lot of credibility when they can't even put a sentence together?
