Lights behind the grill WSI
justvettn
GTA
Theproperedneck
CT/NH
Once again jimmy crafty hands has come up with something awesome. Think i might have to call him right now and get me one of them over nighted.
BramageDained
From my experiences that will DEFIANTLY cause over heating issues..
Have you had your truck get hot? I've managed to put mine in limp mode a few times for high trans temp, but, not yet for engine temp. Even when I was doing 4wd doughnuts at little sahara, the trans got hot and put the truck in limp mode before the engine temp started to climb much from normal. It was 105 degrees that day.
wiz1500
I kicked me temp light on while running on the R.E. Land Rush when the truck was in heavy silt. I'v also seen very high Trans temps on multiple occasions.
Also I had to pull John"s 40" light bar off of his ADD bumper when I was co-driving with him during R.E.'s Desert Heat because we couldn't get the trans temp down..It worked. Also the Race truck had multiple over heating issues when running flat out across the dry lake beds in the Mexican 1000..
I have seen heat and air flow issues on many trucks. I'm not banging on this product i'm just letting you guy's no that if you run this set up hard in the heat you will have over heating issues...
95,505
59,113
SK Raptor R
