GEN 2 Krazy House Customz Slot Delete kit is nice..
PorterW1111
Florida
View attachment 153535this kit is sweet. Not so fun cutting my bumper to fit..Got everything welded up and ready for new skidplate...✌
Let me guess, your fav color is blue? lol
looks killer! those KHC guys do some fine work.
Have you thought about getting your bead lock rings coated to match? Would be cool to carry that blue subtly through the rest of the truck.
Mikee Martin
Mikee Martin
SVC. Krazy House Customz. JDM. Seaside Superbikes
California
The blue is very big when my LEDs are lit up (Grote 18")..During the day hardly notice..Matched the shocks up...lol...Want Kings and Lower control arm for bypass, and straps. im going to try and install a datalogging system like we use on the motorcycles/ havent seen off road guys use wheelspin/ speed/ gyro/ suspension travel, ect. to make the driver able to make calculated decisions for all out performance. i sent rpm an email to see if anyone does this already...the raptors could be way better if we use more than a zip tie on our shocks to see if it is bottoming out. i have yet to find a knowledge source to even bypass the roll control or lock rear end i 2wd...Seaside Supertrucks...working on it..google Seaside Superbikes 15 years of streetbike ********..over it..want to do trucks, seems like there is some areas that could be filled in...lots of awesome fab guys/ looking for advancing the electronics and interfacing motec/ marrannelli magbeti/ or aim with the fords..???????does anyone go beyond ecu programming trans. and engine?
Mikee Martin
Mikee Martin
California
I'm trying to get this on my truck before the Baja 1000 if I end up going. Anyways its the next mod after the Goosetune.
How long did the install take?
if you have not damaged the mounts it takes 8 hours. pretty basic. see photos. make sure goosetune does both the trans and engine ecu programming..i had one bad experience with a programmer who boosted the shit out of my engine but left the transmission peramiters stock, some guys dont realize there is an ecu for the engine, trans, and transfer case...thanks for your feedback..
Dustan
Boulder Colorado
Just wanted to confirm. The heavy duty KHC slot delete kit will have issues with the ADD front bumper where it mounts to the skid plate? I have the Foutz slot delete washers which work fine but don’t give any added protection. Thanks for the info, looks good
Mikee Martin
Mikee Martin
California
Im not sure about the ADD. The bumper I have is an SVC..I had to cut the mounting plate on the bumper where it connects to the frame with the 2 mounting bolts (steering rack) I also had to temporary cut the skid plate for the bumper. The stock skid plate for the motor sucks (tin plate)..this unit makes the truck handle better as it completely tightens up and squares up the frame, providing much more stability for the A arms, and weak points on the frame..now to attach the strut towers, and cash for Kings, deavers, ect......I get so much power when the front skidplate is gone, when I make the new skidplate im going to try and get a ram air system and exhaust for the intercooler. Turbochargers like cold air. I will attest that there is 10% more power with the stock intercooler completely exposed to ambient air with it in the stock position...
