GEN 2 KO2 Tyre pressures on snow on dirt
amREADY
Victoria, BC
This is what they run at RA. Drive paved road to and from. They also run RA in the snow
I find the 4 psi difference is too big in a SCREW and I also have a tonneau, rack, and recovery gear at a minimum (so 250 lbs). In that case, I generally run my rears down 1 psi or 2 and it feels perfect.
When I am running a tent and camping gear as well, I run even pressures.
saym14
Prescott AZ
yup - more load and the rear and you need a few more PSI
EastEndAngler
Long Island, NY
I'll second this as someone with a static 250lbs in the bed. From April to November the truck is on the beach almost everyday, mostly soft stuff. I don't feel like having to air up and have found that 30(f) 28(r) serves me well. If the truck is going back out on the high way I go back to 35F / 32R cold. A few PSI on the SCREW does make a difference.
docskeet1
Athens GA
This is what I started running after Raptor Assault as well. I also used Forscan to reset the TPMS to stop the low pressure warnings (after learning hexadecimal notation). Better traction/larger contact patch, and better ride (purely subjective).
saym14
Prescott AZ
at what PSI does the warning light come on at ? I ran 33/30 offroad and didnt get any warnings ?
docskeet1
Athens GA
I think about 8 psi low triggers the warning light. Nominal is 38 psi. Running the rears at 28 psi set it off.
EastEndAngler
Long Island, NY
Do you know where this is located in ForScan? I'd love to set my triggers to 28 or 30psi
