KIDOR Lemon Law Denied and Suspension Warranty Cancelled
Gsteve
Ford builds a great truck , it does more than any truck every built and had been a great success. Guy take it and beat the crap out of it and add a bunch of shit and expect ford to fix it. Hes wrong and he knows it. Ford says the truck is an off road truck but some guys figure they should be able to beat on it and it will take it , it won't.
downforce137
In Diana
There is no software design flaw. The calibration is designed around the factory components, ride height, spring rate, suspension geometry, etc. Engineering cannot possibly design a calibration that will accommodate every possible aftermarket modification that someone could make.
Well I disagree.. the steering input shaft is getting input from the tires or abs or stabilitycontrol, enough to jerk the wheel out of your hand and cause a loss of control, that's not worth looking into? .. that's a serious problem. Somewhere the wires are crossed and I really doubt 1.5in taller springs are the issue... the rack starts fighting against itself..
GordoJay
Colorado
Mine was doing it in all 3 steering modes, baja and sport in 2wd, advacetrac off with 10sec hold
I feel as though it would do it whenever I was braking for a turn and abs would kick in while the road was washboard or medium bumpy..
Seems like it would show up at Raptor Assault. Unskilled drivers like me braking hard into turns on washboard. Pretty much every truck, every day.
downforce137
In Diana
Maybe.. they also designed the track and do a lot of coaching, no?
I've never been to that so I don't know..
JAndreF321
Lacey, WA
This thread got long in just a day.
I definitely bought my Raptor thinking that I could mod the suspension and body without issues. My concern with vehicles has always been engine modifications. Seeing this does make me concerned about the future prospect of going to 37s; hopefully there is a fix before I get there.
@zombiekiller made a good point regarding the perspective of some owners with modifying their daily driver, since it is often my perspective. You get to a point in life when you can afford nice things, but you want them even nicer and eventually you extend yourself to the point where if something breaks you can't afford to fix it. Then you tell yourself that it is the manufacturer's fault for not building the vehicle strong enough to make up for the modifications you made. This is silly on its face, however, the "built Ford tough" reputation and social media exploding with people making these simple modifications has led people to convince themselves that the trucks can handle anything and are worth the investment. This is where the fact that modifications aren't covered under warranty gets confusing because people buy the vehicles believing they are unstoppable.
The entitlement that people feel with the dealership is another awkward position that I find myself in sometimes...when you work hard and spend $75k on a truck you may have an expectation that the company will do anything to help you. This is, again, silly. Ford is a company like any other and, although it does have a lot of money, it is not at the beckon call of any customer. I'm not sure that the insults and name calling against the youtuber and his family are necessary. They're humans like everyone else and are caught up in both believing "Built Ford Invincible," and having the "I'm a YouTuber/Ford Customer so Ford owes me" mentality. Ford isn't obligated to help them and shouldn't...but it would be cool if someone figured out a solution.
Do 801A vehicles have this problem also? Wasn't sure if there was an additional motor causing problems related to the lane keep assist. How does the steering interact with ABS in off-road scenarios? Dirt causes ABS to kick in and then the steering tries to interfere and control the front end?
GordoJay
Colorado
They tell you what to do, sure. But if you've never done it before and you're being aggro in someone else's truck, you find yourself braking late and going into corners way too fast. I'll bet pretty much everyone does it. As to designing the track, I'm not sure it matters. Braking hard is braking hard, and it gets pretty rutted and chewed up. I think the track is designed mostly to keep the trucks right side up unless someone really blows it.
GordoJay
Colorado
801a has lane keep assist.
Braaaaptor
Starbucks Enthusiast
The drive-thru
It's controlled to an extent yes, when you're on the dirt track it's short to keep speeds down and when you're off road doing the trail section you are following the instructor. That being said, the dirt track gets extremely brake bumpy and the trucks take a beating in the off road section. I certainly pushed the truck way harder than I would my own. It's my assumption if death shake were to occur, it'd be at RA. The Michigan plated trucks go back to Dearborn once RA is done with them for teardown/product development.
Just wanted to follow up on your comment about successful in a lemon law suit. What exactly was involved? My thought has always been good luck when people are going on and on about lemon lawing a car/truck. I've always thought this was a very good representation of what goes into a lemon law suit (https://www.tacomaworld.com/threads/ffs-lets-all-stop-referencing-the-magnussen-moss-act.609911/).
You can probably figure out what my previous truck was from my link.
a lemon law suit is like a gun fight. The best one you can have is the one you avoid.
It starts by being a pleasant person, the kind of customer that people naturally want to help. Even if you’ve had a bad day, you have to be the guy/gal that the service advisor is left thinking ‘what a decent guy/gal’. It continues with you doing your part by taking care of your vehicle as best you can, own any mods you have, especially if you think it’s even remotely possible the tech may interact with them. Honesty goes a long way here, because if the S/A or mechanic think you’re trying to game them, you lose all the goodwill you built up by being a pleasant person.
Ok so you have all that covered, you get a check engine light or something else goes wrong. Document everything you can think of; I was going 65 mph, 2 lane road about 8 at night, steady throttle but, I passed a vehicle about 2 miles back at... a brisk pace, but not racing or anything like that. It was about 2 miles / 2 minutes later that my check engine light came on.
I came home, the car seemed to be running fine, no outward symptoms but, once I got the check engine light, I took it easy on the car until parked.
above is an adequate description - just an example. The mechanic may have questions about things, make sure the SA knows if they have any questions, don’t hesitate to call.
so, let’s say it’s a p0300 misfire. replace a coil or two, return to customer, repeat, repeat, repeat and they keep replacing coils that have actually gone bad, not just blindly replacing them.
let’s say you’ve had the car less than a year and it’s been down 4 or 5 weeks. Now you ask the service advisor for help, hey, I’m having a lot of trouble and this is causing me to miss work, could I talk to the service manager about this? same rules apply: be a pleasant person, empathize with the s/m, he or she doesn’t know you so make sure they conclude their meeting with you wanting to make your life better.
Maybe they wrangle a complimentary extended service plan for you, who knows. Be gracious, but you need to focus on the actual problem and if there’s a resolution. is there a more robust coil available? Are we sure it’s actually the coil, or, is the engine getting so hot that it’s cooking the coils? try to be productive but don’t act like you’re an ASE certified auto engineer if you’re not.
Now it keeps happening, and because service manager knows you now and likes you, they bring in a regional rep. Still no joy. You’re now down for 6 + weeks in the first year for multiple occurrences of the same, relatively minor problem. Obviously if you need the vehicle; commuter, it’s your only vehicle, etc. tell them the warranty isn’t helping because you keep having to return the vehicle for service. This is when customer service should step in with buy back conditions.
But let’s change it up a little and say the misfire is causing stalling, on the interstate, you lose power and have to pull over. Now it’s a safety concern. You don’t wait for 3 repeats on something that’s dangerous like losing brakes or total vehicle shut off before escalating through the stealership.
anyway, skip to the “nothing at the stealership has worked” part.
You obtain the services of a lawyer specializing in lemon law suits. You should have talked to them after the 2nd occurrence of the failure because you know where this is heading. They tell you how to proceed and if you have to sue, what to do.
- file papers, go forward. Laws vary state to state but basically this is the point at which mileage is factored for the purposes of the suit. The lemon law model is typically 4 occurrences of the same or similar issues and / or 30+ days down during the factory warranty period, as few as 1+1 occurrences for a safety issue and you are eligible to sue. basically. You sue.
- your VIN is flagged by the manufacturer. From this point, every service you have performed at a stealership will involve an inspection of the vehicle to attempt to find abuse, neglect, or modifications which void the warranty as it applies to your suit. This will delay any service including routine maintenance. When I did it, they sent a regional rep to inspect the vehicle each time.
- now you wait. The first thing the manufacturer does is stall and delay. this can be from as little as 6 weeks to as long as 18 months. all the manufacturers are different but they generally first offer non binding arbitration, my lawyer explained that 95% of these are in favor of the manufacturer so it’s generally a waste of the plaintiff’s time.
- when arbitration comes back in favor of the manufacturer, your lawyer expresses your desire to push forward.
- final attempt to remediate; once sued, the manufacturer gets another attempt to repair if they want. this is not negotiable if the law gives the option, they always do this and you don’t get to say no and continue the suit. You need to have representation at this attempt of repair because the manufacturer will.
- wait some more. Mechanic will work on the vehicle and update the ticket. A report is made / delivered to the lawyers for the manufacturer. They will sit on it for a while, even if it says ‘this thing is a death trap’. Their strategy is to hope to outlive you because if you pass away or some other major ill befalls you before trial and you cannot proceed, they win.
- next is usually a pre-trial settlement offer. This is usually a token amount of cash or offer to trade in on a new model at invoice. Like purchasing, this is a negotiation.
- next is a just before trial settlement offer. This is typically a vehicle ‘swap’ - you surrender your lemon the stealership sells you a new model crediting you for the lemon and whatever terms were negotiated. Usually it’s a swap with charges for mileage, token legal fees, etc.
- if you decline, trial will commence where you get to make your case via your lawyer, expert witnesses. The judge may order you and the defendant to negotiate more. He or she may do so with “clueful hints” to one side or the other that they should be more receptive to settling. If so, and it’s your side that is given the clueful information, it may be worthwhile to be more willing to deal. If you lose at trial, you could be out a bunch of cash. if it’s the other side and they sweeten the deal but not enough, your lawyer will tell the judge they couldn’t reach an agreement.
- if it’s cut and dry you may not need to take the stand, but if it’s a bit of an oddball issue then you may need to articulate why this significantly impacts the use and market value of your vehicle.
- they will claim abuse, neglect, modifications caused the problem usually. They will come up with expert witnesses who will back them up.
- you get to do the same.
- at any point along the way, either side can still offer to settle.
Manufacturer settlement offers that meet your standards for being made whole is probably the best possible outcome of a suit that goes far. They don't admit wrongdoing, etc. and either buy you out or put you in another vehicle.
if you leave it to a jury, who knows what happens. Sometimes they rule for you when they probably shouldn't, other times they may not get why your case is such a big deal. They may rule for you but not cover legal expenses, and so on, and so on.
My suit took 14 months from filing to completion.
Members online
96,586
60,555
CleverGirl77
