JL Stealthbox question
P
Pittmd
Can you give me prices for both the single and double boxes with the 10tw3 subs. If I go with 2 subs, I would likely go with the HD 600/4 to drive the fronts and rears and the HD 750/1 to drive the subs. Does this sound feasible? Also, if I go with the single sub, I'm guessing that the HD 900/5 would be too much for the single sub....is this true? Lastly, can you give me a rough time frame for getting a box made? Thanks again for all the help.
LFtrip
Glendale, CA
I have a quick question, hopefully you'll have the answer Noah. I have an old 10" Kicker Comp VR and was wondering if its possible to make a box that will fit in an SCrew. It still work so I figure keep using it till I finish the other mods on my truck. I dont know the demensions on the sub but its pretty old. I bought back in 2003 when I still lived in the bay area. My Raptor is a 2013 and I didn't get the sony package / navigation. How hard will it be to hook everything up?
The Car Stereo Company
here, on frf
a woofer that old might not last too long. install shouldnt be a problem even if you dont have the 801a. i think it might be easier. the cvr woofers were definitely shallow enough but i would upgrade it. if you are going to spend the money on a custom fit box, it might be best to use a better quality woofer. i can build you a box, but it is usually custom fit for the woofer. so if you replace the woofer, the box might not be ideal for the next woofer you get. with the crewcabs, i need 2 of the oem brackets. and since you dont have the sub, i will have to order a set.
LFtrip
Glendale, CA
I'd love to buy one of those JL stealth boxes but my wife might make me sleep in the truck if I do. For the install, would I have to pull the dash apart to get behind the head unit? It seems easier to plug into where the factory sony subwoofer would be which I don't have.
bakkbakk
House
if you get a 2 sub setup for the tw3's where do you put the amp?
How much is the cost for a 2 sub box from you and how long will it take?(don't have the truck yet but almost so its not a need it now thing)
here, on frf
most people will put the amp on the passenger side where the oem sub used to be.
pm inbound
bakkbakk
House
so your 2 sub set up only uses 2/3 of the space under the seat and leaves room for the amp? Nice. The "big box" sub box makers take up the whole space not leaving room.
Do you have a picture? I have been reading your threads all day and haven't seen a 10" dual sub setup yet.
Maxx2893
Rock and Roll Offroad
Burleson, TX
Just throwing my opinion in here. If your on the fence, I recommend The Car Stereo Company 110%. Great products and amazing customer service (as you can see).
bakkbakk
House
its not really about being on the fence, my questions aren't questioning his work, its trying to figure out what I am buying and all of my options.
