jackrook's 2013 Screw build thread
jackrook
jackrook
Bermuda Dunes, Ca
Just catching up on your build Jack...good stuff as usual. I wanted to ask if your k&m is a dry filter? If not, make sure to carry your stocker on runs or swap it out. Reason being, the wet filters are easily clogged with dust and debris. One of the members on the Carson run was running a wet filter and his became clogged and his truck would loose power at higher speeds. Again, ignore my comments if it's a dry filter.
It's this one here. Requires 65ml of oil after each wash. Goes between 50,000 miles between washes (I'm sure that's for street queens)
http://www.knfilters.com/search/product.aspx?prod=33-2385
slowest member of WCPR
