Is it normal to have power loss in heavy sand?
New Guy
TEXAS
around 20 psi.
^Sweet, thanks for finding that out. I will be going to Assateague Island more often in the future and the first time I never aired down because I thought that was unneeded but learned the hard way shortly afterwards.
wanderfalk
I've noticed one thing just messing around my town, if you only fully disable traction control, you can burn the tires off. But after you drive to the next sign or light it kicks it into sport mode instead of fully disabled. Might be when it reaches a certain speed? Also noticed if I put it in ORM its stays fully disabled.
what is sport mode?
Chavante
High Country, CO
My TPMS went off and won't go away.... -25 in the mtns this morning is this NORMAL....?
I HATE TPMS!!!! Same BS happened on Tundra... Do you...?
Wilson
South Dakota
Put air in tire^
---------- Post added at 01:21 PM ---------- Previous post was at 01:21 PM ----------
Don't forget to check the spare
SilentShooter
Siesta Key, FL
If you are going to run around it temps that change drastically and you are not planning on airing up/down then nitrogen is a good idea. If airing up/down then it would be a waste.
bambo2888
South Florida
I don't think nitrogen works as good in cold
it does... had my tires inflated with nitrofill about 5 years ago and have been using it since. doesn't leak out as fast and tire pressure stays a lot more consistent when temps drop... i was told it was because of the absence of moisture, which makes sense. Haven't had a tpms light come on yet.
