Interior Raptor Emblem Install Question
Humvee21
True... But mine is going to be made with razor sharp edges. Clean cut...
Bluoval1118
Ft. Huachuca, AZ
If you do follow through on your idea, I'm sure a belt sander would easily make the backside as flat as you would need. When you apply the emblem wipe down the area with rubbing alcohol and use some sort of adhesion promoter to help the emblem stick better. Good luck
whisler151
Dallas, TX
While you are at it, AutoZone sells many other emblems. I'm thinking a "turbo" or "deluxe" would look good in the cabin as well.
Aaron
Meme Corps Commandant
WA
I'm going for a Type-R myself...failing that maybe a Mugen one or something.:ROFLJest:
I really don't think the raptor logo would look too bad inside, but placement might be hard because you definitely want to avoid the airbag.
Gen1Rap
Nipomo, CA
Try a Raptor decal on the smooth surface of the trim instead. I've seen many vendors of stickers in all kinds of colors. If you get tired of it, you can always peel off and goo gone the stickey. Just my .02
:waytogo:
