BlueGoliath96
- Joined
- Feb 11, 2018
- Posts
- 104
- Reaction score
- 102
I'm sure that driveshaft is fine but I'm partial to the Dynotech. Mine has performed absolutely flawlessly (even at 575 RWHP with heavy tires), and it even survived a really nasty hit caused by a bozo moment from yours truly. I have so much confidence in it I had it repaired instead of replacing it.
Unclear to me if a driveshaft is absolutely necessary, though. I only did mine because of the Whipple (and because I no longer have a speed limiter). I don't really do any ludicrous speeds in the truck but every once in a while it's fun to let it stretch the legs a bit.
What's your suspension set up currently?
What about brakes? That's important.
https://sdhqoffroad.com/products/10-14-ford-raptor-dynotech-aluminum-raptor-driveshaft you mean this one ?
1- Fox 3.0 complete setup adjusted equivalent top perch +
2- Total chaos 1.25 UCA
3- Stock LCA
4- Deaver +2
5- Fuel JM2 +7 offset
6- 1.5 inch spacer Hubcentric
7- S&B air intake
8- Optima battery
I will email them and see what’s the perfect match with 40s .
