BlueGoliath96
- Joined
- Feb 11, 2018
- Posts
- 104
- Reaction score
- 103
Looks good man.
Thank you bro
Looks good man.
Looks good! How does it cycle?
The tread pattern on that tire is your biggest issue with handling. The lugs aren't perfectly round on there, so you get some wobble from that. The best riding 40" mud tire I've seen is the Toyo MT. I know you already dropped the coin on these, but going with the Toyo would improve the ride considerably.It’s looks badass but you sacrifice handling it doesn’t handle as good as the Mickey Thompson Baja atz p3 that one was 37x12.5 , did some mild off-roading loose sand the truck moves from side to side maybe becuase the tread on that nitto is soo frickn wide 13.5 and at the highway there is some steering wheel movement (vibration ) not crazy
Or, the KM3s in 39 x13.5x17The tread pattern on that tire is your biggest issue with handling. The lugs aren't perfectly round on there, so you get some wobble from that. The best riding 40" mud tire I've seen is the Toyo MT. I know you already dropped the coin on these, but going with the Toyo would improve the ride considerably.
I think your math is a little off - the Mud Grapplers weigh 111 lbs, or 50.5 kg, and 39.7" diameter.Yes they are 39.5 approx something like that , but they are heavy as hell 45 kg
