Installing 40 inch nitto tires ( re gearing
BlueGoliath96
BlueGoliath96
I'm sure that driveshaft is fine but I'm partial to the Dynotech. Mine has performed absolutely flawlessly (even at 575 RWHP with heavy tires), and it even survived a really nasty hit caused by a bozo moment from yours truly. I have so much confidence in it I had it repaired instead of replacing it.
Unclear to me if a driveshaft is absolutely necessary, though. I only did mine because of the Whipple (and because I no longer have a speed limiter). I don't really do any ludicrous speeds in the truck but every once in a while it's fun to let it stretch the legs a bit.
What's your suspension set up currently?
What about brakes? That's important.
https://sdhqoffroad.com/products/10-14-ford-raptor-dynotech-aluminum-raptor-driveshaft you mean this one ?
1- Fox 3.0 complete setup adjusted equivalent top perch +
2- Total chaos 1.25 UCA
3- Stock LCA
4- Deaver +2
5- Fuel JM2 +7 offset
6- 1.5 inch spacer Hubcentric
7- S&B air intake
8- Optima battery
I will email them and see what’s the perfect match with 40s .
BlueGoliath96
BlueGoliath96
Also yea the stock brakes can’t handle this much of weight , do you guys know any reputable brands that work with 17 inch wheels ?
PS . I also have 1.5 inch spacers so idk if this works ?
SlickTrick
Massachusetts
Pretty sure Alcon Kits makes a brake kit for 17s... I would def send them a Email and tell them what your doing.. I can’t Amagine what stoping in that truck is like.
BlueGoliath96
BlueGoliath96
I will check them out , got a lot of upgrades to accommodate with this tire , and yea I don’t feel I’am braking tbh lol [emoji28][emoji23]
Here are the recent shots [emoji1303][emoji1689] 3ac9a0207bc058f032d8203534fa9dc3.jpg
5280_TIM
Parker, CO
Looks good. Do u have any photos where it's not dark? The best part of your truck isnt very visible...the 40s!
Sent from my SM-G965U using Tapatalk
BlueGoliath96
BlueGoliath96
Just Purchased Nitro Gears 4.88 front and rear about 1400$+ Re calibrated with SCT approx 510 revs/mile with 40s just need to adjust the gear ratio
pastorwug
Santa Maria, CA
It's just not a reasonable venture top go to 40s, it's a huge expense and mod list - and for what? Bragging rights? Crawling bigger Malls?
Unless you have a specific use, or Black Diamond Trail you want to conquer, spend you money on modding to 37s - much better uses and won't break the bank as much!
