zombiekiller
OG BooBooRunner
Do you have a part number?
JL3Z9B325D (that's for an 18), should be right around $58.
And yes, it is called "fuel tube support"
thanks for the info.. where can i get that heat shrink clamp from?JL3Z9B325D (that's for an 18), should be right around $58.
right now I have the factory line back on there, secured with a gates heat shrink clamp. I bought a new OEM line too, which I am going to swap in once the truck gets out of the shop. Reason for going with a brand new line, is the valve that the line goes into is actually part of the ford part number. That valve is related to fuel pressure and I dont want to take the chance that it has been compromised from the ticked/valve flutter from the turbosmart line.
So when you order the new one, does it come with the valve? if so, did you install yet?
I'm seeing this now as i am looking online for it. So you are going to install the whole shibang then? please post how that goes.So when you order the new one, does it come with the valve? if so, did you install yet?
also, do you know which size wrap you used to put old one back on?
Turbo is what their name is now.Here is turbosmarts response to my sprinkler noise question. They know the problem and still worn fix it.
“Thank you for contacting Turbosmart. As our instructions state, after fitting this product there may be an audible ticking noise emitting from the EVAP circuit lines, this is normal as the sound is no longer damped and not a cause for concern. The noise is created by the EVAP solenoid actuating. The OE hard line deadened this noise but the softer silicone hose we provide is able to expand and contract allowing sound to travel through it. We currently do not have a recommendation on how to make the noise go away.”
Here's another good example. how about making another adapter to KEEP the existing hose and basically stack the connection? Or, supply a TB spacer.My response to them:
“So in theory, a better hose should be a simple solution to the issue?”
And their response back:
“I wouldn't necessarily say a "better" hose would solve the issue as our hose is perfectly fine for the application. The harder the hose the less noise you would hear because the less the hose can oscillate. You can take a look at the OE line you removed to have an idea of how stiff it would need to be to quiet that noise.”
You would think they could choose a new tube that would keep this quiet like stock. Almost makes it sound like you have an exhaust leak.
