Installed 37's on Gen3 35 Raptor - no issues.
TXRaptor37
georgetown. tx
Well these are actually up for sell now on Garage Sale. I love the set up but going to go for a blacked out look and back to Toyo RT Trails which I run on my Bronco and love them. Post below of the listing if anyone is interested. I’m located just north of Austin, TX. Thanks!
lolsike
Edmonton, AB, Canada
Here is my 2023 35 package, completely stock with RRW RR5-H in 17x8.5 et0 wrapped in MT Baja Boss AT 37x12.5
Rubs slightly in reverse with the wheel turned. Temporarily removed 1 fender screw on each side to prevent grabbing.
Wednesday it’s getting SDI top hats, FMI rear 1” spacers and a set of caster/camber plates on the LCA’s. Adding some caster will push the wheel off the firewall and prevent rubbing throughout travel. Also have a set of billet “beauty” rings for the wheels set to arrive next week.IMG_3831.jpeg
lolsike
For everyone that’s read all 51 pages but is still confused why some people are fitting certain combos and other arn’t. Here is a really great breakdown of how to fit larger tires that applies to most IFS.
3 biggest variables. You can trade some off for another.
1. Wheel offset
2. Tire width
3. Caster
cdiddy4224
USA
found some brand new Raptor R take offs on FB Marketplace and installed on 35 Raptor. Zero rub on stock suspension on the 37” KO2. Doesn’t feel too different accelerating as these are fairly lightweight
Love the look but might swap tires for a hybrid like a Nitto Recon of Toyo RT Trail but keep the wheels as I love the style
Keep in mind, the Nitto's I believe are a true 37" tire, where the BFG KO2s are not a true 37"
taquitos
Seattle
I feel like I'm beating a dead horse, but there is an option for this truck that actually replicates the wheel clearance of a 37 truck at full compression. The wheel wells are identical on both trucks. The difference in clearance comes from the bump stop height. It's actually possible to increase the bump stop height without decreasing travel as it turns out. There's a whole thread on that here for anyone that hasn't seen it/is curious what I'm talking about https://www.fordraptorforum.com/threads/new-suspension-components.104616/.
Now I get the feeling that a lot of people just go "oh that's not necessary these things won't rub at all". If you're driving around on the street that's fine and all. The bump stop won't compress enough to access full travel anyway. Ford didn't use different bump stops and shocks between the 35 and 37 trucks for no reason, though. If clearance was all fine, they could have used the same shock and same bump stops and saved money/increased their margins. In my opinion, the difference in shock tune and front shock shaft size is driven by the fact that they have less travel as opposed to be a real upgrade. In product development, that sort of thing usually corresponds to a change driven by necessity as opposed to intentionally added value. If you decrease travel and want similar bottom out, you have to stiffen the shocks. That in turn imparts more stress on the shock shaft. 37 trucks and the R also have about 0.25" more preload on the springs than 35 trucks so rebound is a little different. Shock tune is a whole other conversation, though.
Anyway, back to wheel clearance talk. What I see overlooked all too frequently is the fact that there is a ton of elasticity built into the system. The entire cab and front quarter panels/wheel wells sit on rubber body mounts. These have at least 0.5" of range of motion on compression. That means if you hit something really hard, the entire body of the truck excluding the bed will move downward 0.5". So, if you jack the wheel up to check clearance, there's at least 0.5" less clearance that what you will see. If you watch slow motion videos of trucks jumping and see it look like the front bumper is bouncing around a lot, that's actually the whole body bouncing. The bumper is fixed to the frame. I'm actually surprised that you don't see more people with aftermarket bumpers blowing that piece of trim right above it off the truck since a lot of those bumpers have very little clearance to it. I guess that might just be because the truck isn't often pushed to its limit. There was some guy on youtube who did a video about bending tie rods that had it fly off and chalked it up to lack of quality, but I think it was really his bumper that did it so no fault to Ford.
The other thing I see overlooked on multiple fronts beside that is what kind of impact or wheel displacement in the rear is of most concern. Jumps with even landings where both wheels can touch down at the same time do not test the clearance of the rear. You can bottom so hard you break many things without having wheel rub in that scenario. Where wheel clearance is lowest is at full articulation. For reference I've attached a picture someone posted on facebook a little bit ago. It's a 35 truck with 37s on. At near full articulation but entirely stationary, there is practically zero clearance. If you're crawling that's fine, but the bump stop is not entirely compressed. If were to land heavy on one side first or just be moving fast while hitting full articulation, you'll close that up. Interestingly, there was someone on here in a thread about 39s or 38s that had put 38s on their 37PP and had rubbing issues here and that's only a 1" bigger tire. IMG_8676.JPG
