Installed 37's on Gen3 35 Raptor - no issues.
socal raptor
Los Angeles
No there’s no perch mod. It’s stock right now. I figured I would try the set up first to see if it worked before doing anything else. I will either get a collar or start trimming.
crc
Heath TX
Does anyone know the Gen 3 difference from Gen2 35 Packages ? 37 “ tires on a Gen 2 sounds difficult ?
mattio
I thought the difference between the 37 and 35 package in gen 3s were minimal. Suspension was valved different and the bump stops are different… that was about it if I recall.
SCMike
San Clemente
There is definitely more work involved in fitting 37s on a gen2. The major problem is the fender wells are not big enough, so you have to do some trimming and hammer the pinch welds flat.
The Gen3 only requires a perch collar and the correct offset wheels. These things were made for 37s to fit in the fender wells.
tm965
NOVA
does it actually require the perch collar... ive seen comments suggesting it does not
SCMike
San Clemente
If you are street driving it might work without a perch collar, but off-road, no way I’m not sure why you would not do it. The 1.5 inch collar don’t change the ride one bit. Mine actually rides better than when it was stock. I think the 37s add a bit more cushion.
tm965
NOVA
i agree that the 37 seems to ride a bit better, but the one i was driving was aired down a bit so not so sure. sounds like there are mutliple accounts of ppl running 37s off road with zero issues. its not like the perch collar is limiting travel
Erjdrvr
Indy
Just ran the MOE event in Michigan over the weekend with a 35 on 37's. 37x12. 5 KM3'S on Alphaequipt 17x8.5, +25 offset. Ran it pretty hard over whoops & think we were airborne once with no rubbing. It seems to sit maybe 1/2" to 3/4" lower than a true 37pp I measured at Raptor Assault.
Haven't ruled out maybe the SVC 1.5" spacer in front & maybe 1" spacer in back. Just not sure what I'd pickup in performance?
Hemmy
Indiana
View attachment 356338View attachment 356339View attachment 356340
Where was this at in Michigan?
