Install new Tow Hooks
figure1a
San Diego
Put the tow hooks on today. Sharpens up the front end a lot. I suggest taking off the skid plate. A lot easier that way. I used the original dust covers, not a perfect fit but worked.
Those will bend under a real load. Steel is way stronger than aluminum (even 6061). If those were 3" thick, maybe they would have the same strength as the stock steel hooks.
Aurik
Near Denver, CO
I recently saw a Bronco Raptor with code orange tow hooks and trim rings -- I'm thinking I'm just going to reusemy factory ones and have them powder coated along with the wheel trim rings...
CoderRaptor
Denver
So I bought a set of R tow hooks off ebay to install on my 2024 801. I noticed some guys don't use the shroud after install. Seems to me that shroud is for aero purposes...So I want to put it back on. However, It looks like the one they sent off eBay is a little different than what is on my truck. Make sense given the different design of the hooks. So I will report back what I find when I do the install.
Anyone else walk this road?
spidrak
I just had my R tow hooks (Ford Factory) installed today at the dealer. The lower seal does not/will not work with the new hooks, it bothered me enough I went to a dealer to look at what the R had, those seals are different. I have no idea if they would even work on the standard bumper.
CoderRaptor
Denver
So the seals they sent with the new hooks are different. I can tell that much. It looks like the just slide over the hook and tuck behind the bumper. I hadn't thought if they were bumper specific or not. Hmmm. I don't want to do the swap if I can't get the seal back in. Thanks for the input.
Did you go without the seals?
Evasive
FL
How did the R shrouds fit? I have a set that came with the R shrouds (which was a nice bonus) and was going to do the install tomorrow.
Evasive
FL
Did the install today. The R shrouds fit but I had switch the Left and Right otherwise, on my 2022 37, the gaps were big. Also, double check the vertical clips are in correct. You don’t want them mushed under the tow hooks. Easier to loosen the skid plate or remove it.IMG_4920.jpegIMG_4919.jpegIMG_4918.jpeg
