Install new Tow Hooks
2orque43
Philadelphia
Soft shackles are the way to go, I have a bunch of the Gator Jaw ones off amazon - Have a few for my ATV's and they hold up great.
Nex
RIP CoronaRaptor
Washington State
No hook, that can turn into a missile.
Soft shackles work in place on the old school D shackles. You attach your tow rope to a mount on the vehicle with the soft shackle.
Edit:
Unless you mean "tow hook" like the mounted recovery points on the Raptor. When I hear tow hook I am thinking a hook attached to a stap of some sort. Not the recovery points.
downforce137
In Diana
You still need a tow hook or a really stout frame member, right?
Yes of course, but using heavy steel shackles or chains is def not ideal, especially if using a moving truck to yank it. I only use hard shackles or chains with winches and even then it's a last resort type of thing. Things go real bad with metal parts flying around at 100mph if something breaks
PolishMaffia
newyork
Put the tow hooks on today. Sharpens up the front end a lot. I suggest taking off the skid plate. A lot easier that way. I used the original dust covers, not a perfect fit but worked.
KostaNYC
Does anybody know if the front tow hooks are the same as the rears? Not sure if the make different ones for the back. I can't seem to find any info on that.
